Engine stall if I press the throttle after diesel mix - Page 2 - Polaris ATV Forum
post #11 of 12 (permalink) Old 02-17-2017, 05:52 AM
stave7119's Avatar
Interesting! Never seen that before, but I am glad you found the problem!
1st Machine
2001 Magnum 325 with a blown engine; rebuilt 2004. Broke timeing chain 2016 rebuilt again and still running. Warn winch and Moose 60" plow
Wife's machine:
2007 Sportsman 500 EFI, Polaris Winch, 26" Bear Claw HTRs on Moose 427x Wheels. 12x7 front, 12x8 rear, QSC Clutch Kit
My Trail Machine:
2004 Sportsman 600 Twin, 25" RipSaw Tires on stock steel wheels, Moose rear box
Completed Project machine:
2001 Magnum 325 MOSE with a blown engine. Transplanted a 2005 Magnum 330 engine. Committed suicide on the trail Oct 2016. Spun Rod Bearing after oild cooler line failure. Rebuilding Engine.
stave7119 is offline
post #12 of 12 (permalink) Old 02-17-2017, 02:09 PM
sportsmatt's Avatar
Originally Posted by Santo9 View Post
End of the story . I find the problem and solution in the carb , the needle jet was broken in 2 part and showed high level of wear. But they broken in the middle not on the very wear part .i add a picture to show you
Sportsmatt you was wright , nothing to do with diesel .
.....And I wasn't trying to be a jerk...but it just didn't make sense to me.
Good job getting it fixed!
sportsmatt is offline
Common Carb Issues pfunk76 ATV Repair and Maintenance 113 01-06-2017 08:47 PM
Exhaust wazupec Polaris Sportsman 7 11-29-2016 05:08 PM
Scrambler 850 stuck throttle check engine light tjp2473 ATV Repair and Maintenance 0 09-12-2016 12:22 PM
850 throttle issue aceman ATV General Discussion 2 05-10-2016 10:21 AM
Blown engine worth fixing? Aedude006 ATV Repair and Maintenance 13 03-03-2016 06:56 PM
