07 500 efi moving at idle - Polaris ATV Forum
Old 02-24-2011, 09:21 AM
jtmcc72's Avatar
Member #12348
Have an 07 Sportsman 500efi that is moving in gear at idle. Yes I know that this us usually due to a high idle, but the idel is good. Dealer wants to install some shims in the Clutch but I thought that only fixed the clunk when you shifted into reverse or high/low. Could dust/dirt in the PVT cause the belt to grab making the belt grab? What do you guys/girls think?
Old 02-24-2011, 09:38 AM
skiboat's Avatar
Member #10881
this would be a clutch alignment problem & yes shims will fix it sometimes.possible you could have a broken trans or motor mount to.
Old 02-24-2011, 10:25 AM
Old 02-24-2011, 10:49 AM
jtmcc72's Avatar
Member #12348
Thanks for the Welcome..
I have a feeling that the mis-allignment is the isssue. Its my Dad's 4 wheeler and I was just kind of checking into possible causes before he took it in. He had a big big wreck with it 6 months ago and when it was all back together is when the problem started. Im sure something got knocked a little out of wack and is now off. Weird thing is that it dosent do it all the time.. maybe 7 out of 10..
Thanks for the info though.. Much appreciated.
Old 02-25-2011, 02:04 PM
Allred's Avatar
Member #12291
I had same problem with 2001 550 sportsman, alignment good, belt good, dealer replaced what he called grooved primary clutch...$400! Problem came back within 100 miles of riding!
Son and I decided to look into it ourselves, tested with clutch cover off, close observation looking and listening, we determined that the engine braking portion of the primary clutch was not releasing as it should, putting a load on the gear box, making it very difficult to shift, and causing the bike to creep at idle rpms.
Cheap fix...We simply changed from the engine braking system model drive belt (which is slightly smaller in diameter than standard) to a standard sized belt (for machines without engine braking clutch installed). The standard sized belt rides just a tad higher in the primary clutch, and does not engage the engine braking portion of same, and does not ride in the "groove" the dealer described.
The creeping and shifting difficulty was gone! Have ridden in this configuration for several hundred miles since with no difficulties. And....there still is noticable engine braking available, though not as much as before.
Go figure. May not be your issue, but worth considering.
Allred
Riverton, Utah
Old 02-25-2011, 04:03 PM
racer37l's Avatar
Member #5629
Make sure you check the engine mounts also.
Con
07 polaris sportsman 500 idle
idling issues efi atv motors
polaris 500 sportsman moving at idle
polaris atv belt grabbing
polaris atv efi motor mounts
polaris atv moves while idling
polaris moves while idling
polaris sportsman 500 belt grab
polaris sportsman 500 creeps
polaris sportsman moves at idle
polaris sportsman moves at idle creeps
sportsman 500 moves while in idle
Shifting from LOW to HIG while moving? brumey Polaris Sportsman 4 07-12-2010 10:59 PM
99 Trailblazer FUEL slashes when moving sledsrus1 ATV Repair and Maintenance 0 07-09-2010 09:40 AM
atv moving by itself blksportsman Polaris Sportsman 11 05-12-2010 07:52 AM
sportsman 500 moving by itself when put into reverse. orangej Polaris Sportsman 4 12-17-2009 06:50 PM
noise when i start moving stickem Polaris Sportsman 3 08-20-2009 03:14 PM
