Suggestions for pulling front CV joint cup from differential - Polaris ATV Forum
post #1 of 5 (permalink) Old 03-19-2017, 01:11 PM Thread Starter
trackhound's Avatar
2006 Sportsman 500 EFI X2
So this is all that left of the front right axle assembly.
I originally cobbled up a slide puller to the outer axle end, "pulled/slammed away at it and the inner CV joint fell apart rather than come out of the differential.
So, Id read on here a suggestion to grab onto the cup with a vice grip and attach a slide hammer to that but cant figure out yet how to securely attach one to the other
Any other suggestions on how to extract this piece?
It looks like the splined shaft is stubbornly retained by a simple wire C clip..Correct???
ID:	74065   Click image for larger version
ID:	74073   Click image for larger version
trackhound is offline
post #2 of 5 (permalink) Old 03-19-2017, 04:51 PM
Roost5o's Avatar
That clip is what is keeping it on. Well that and grime/rust and whatnot. I was able to pry all of mine out even though they had slight rust and were bone dry.
Roost5o is offline
post #3 of 5 (permalink) Old 03-19-2017, 05:07 PM
FPD218's Avatar
Drill a hole through both sides and put a bolt through it for the slide hammer to grab on......
2006 Sportsman 800 EFI Twin
*Front and rear brush guards
*Front and rear rack extenders
*Rear Polaris storage box
*Warn 3000# winch w/wireless remote
*Second battery
*52" snow plow blade
*19" windshield
*Hand warmers
*2" receiver welded to front guard
*EPI Heavy Duty springs front and rear
*Nebulus Flotation System
*Garmin GPS
*SilverBack
*Purchased new to me on Aug 08 2016 97Hr 811Mi
FPD218 is online now
post #4 of 5 (permalink) Old 03-20-2017, 03:40 AM
indyred570's Avatar
I attached the vise grips to one side of the cup & then put a large screwdriver behind the cup on the opposite side. Pried & pulled at the same time.
I did soak mine down with PB Blaster which I think helped. You can always rebuild that axle and keep for a spare, so I wouldn't drill holes in the cup.
2014 Sportsman 570 (Red)
Powermadd Hand Guards
Viper Elite 3000 Winch/KFI mount
Denali Snow Plow
Polaris HD Front Springs
Kenda Executioners
indyred570 is offline
post #5 of 5 (permalink) Old 03-20-2017, 07:11 AM Thread Starter
trackhound's Avatar
Got it off...will post pics later
05 front differential doc0810 Polaris Sportsman 4 09-07-2016 02:58 PM
2014 Sportsman 570 Front Differential Leak instagramfinggaz Polaris Sportsman 570 10 08-16-2016 04:35 PM
05ish Front Differential Cover with Coil. fallout232 ATV Parts Wanted 0 06-12-2016 09:21 PM
Hub strut compatability sniper4x4 ATV Brakes & Suspension 3 04-05-2016 07:24 AM
