Old 02-25-2011, 03:06 PM
Hunter11's Avatar
Member #7172
Starter Solenoid Help
A couple of weeks ago my 03 Sportsman 500HO would not start a week after I had taken it on a trip to the ranch where it worked fine. It would only click and nothing else. The battery is new and has been checked so I ordered a new starter, solenoid and bendix from DB Electrical. While waiting on the parts I pulled the solenoid figuring to replace the easiest part first and go from there. Well I got the parts today and the solenoid they sent does not match the one I have that came off the bike. Mine has the two big connectors for the battery and starter connections and a red wire with a male connector and a black wire that was connected to one of the bolts holding the solenoid to the battery box. The one they sent me is in the link below. Anyone know how to make the new one work?
DB Electrical - NEW Starter Solenoid Relay for POLARIS ATV SSE6002
I am wondering if I need the black ground connector and if I could just cut the red wire off my old one and use it on the new one like in the picture. Also can I check the old one with a OHM meter with it off the bike to see if it is bad? Thanks for any help as I was looking to get this thing back running this weekend.
03 Sportsman 500 HO
Old 02-25-2011, 03:50 PM
Ifightfires's Avatar
Member #10643
Ground the black wire just to be on the safe side. If it is marked, be sure to put the battery on the correct side of solenoid. You should be able to take remaining wire from machine and hook it to wire on solenoid. i would suggest crimping mating connector on machine as to not alter solenoid in any way, in case you have to send back. If it works (it should) then make it a permanent installation. Good luck!
2001 Trailboss 325
Mountain View Mo., Fire 1+2 certified, hazmat ops certified, vehicle rescue technician.
I fix everything myself, if i cant, it don't need fixed! 10 yr electrician
Old 02-25-2011, 04:07 PM
Hunter11's Avatar
Member #7172
The small black wire is on the original solenoid and is connected inside as is the red wire. The new one has no black wire and no way I can see to hook one up. I was thinking maybe I could cut the small red wire off the old one and put a spade connector on it and attach it to the new one then hook the two big wires (battery and starter) up and it should work if it does not need the small black ground wire on the new one. I never though it would be this big of a PIA to replace the starter solenoid.
03 Sportsman 500 HO
Old 02-25-2011, 04:38 PM
tt425's Avatar
Member #3687
I think the black wire is just a extra ground wire. Make sure the new solenoid has a good ground. The red wire comes from the start button to the solenoid to engage the starter. Older model Polaris atv's only had the 2 battery cable connections and the small red wire. If its above a 2001 Model I can't help you very much. Put a test light on the black wire and make sure it's a ground wire.
1995 GMC 1500 Ext. Cab Z71 5.7L
2010 Chevrolet Equinox as of 3-29-13
1996 400 Explorer 4x4( project purchased 12-30-11)
2 1995 425 4x4 Magnum's
1996 425 4x4 Magnum
1998 425 4x4 Magnum
2001 Honda 350 Rancher ES 4x4(nothing like a Polaris,rides like a log wagon and no power,lol)
Old 02-25-2011, 04:43 PM
Hunter11's Avatar
Member #7172
It is an 03.
03 Sportsman 500 HO
Old 02-25-2011, 04:55 PM
tt425's Avatar
Member #3687
I seen that it is a 2003. I am telling you I have only worked on 2001 and older models. Check the black wire and see if it's hot. More than likely it's a ground wire. The small red wire is the starter button wire and it makes the connection inside the solenoid to both of the cables sending power to the starter. When you let off the start button the red wire is dead. That solenoid is the same solenoid used on lawnmowers for years.
1996 425 4x4 Magnum
1998 425 4x4 Magnum
1996 polaris sportsman 500 change starter selanoied hook up wires diagram
2002 polaris sportsman 500 ho not starting with key
atv ground to starter solenoid
fix starter coil on 350 polaris
how to change2005 polaris sportsman 500 starter solenoid
how to hooh up a silonid for a 2003 polaris magnum 330
how to hook up a 1996 polaris xplorer 400 starter solenoid
how to hook up a starter solenoid on a polaris 300
how to wire a starter selector switch
polaris 2001 sportsman 500 ho starter solenoid
polaris 500 starter relay
polaris starter relay ground wire
sportsman 500 starter hookup pictures
sse6002
tt425 hazmat code
Starter solenoid wiring ? Dom ls2 ATV Repair and Maintenance 3 02-22-2011 09:52 AM
Gut feeling solenoid is bad. scottdeet ATV Repair and Maintenance 2 09-13-2010 09:06 AM
Starter Solenoid replacement on 97 sportsman need help! rinkrat33 ATV Repair and Maintenance 3 03-14-2010 01:04 PM
2002 Sportsman 400 Starter Solenoid Wiring? osmosisfrank ATV Repair and Maintenance 3 11-27-2009 05:44 PM
How to reconnect starter solenoid? cuzinclem ATV Repair and Maintenance 3 11-08-2009 02:37 PM
