02-26-2011, 01:34 PM
Member #11479
Winch electrical question
Each time I turn key to on winch solenoid clicks. Is this correct ? Or should solenoid only click when you use winch ? Dealer installed winch, first solenoid was bad first time I needed to use it. Replaced solenoid wired it like dealer did. Used winch a few times. Now winch does not work again. Solenoid still clicks when key turned on. Have not check for power or continuity. Just want to make sure solenoid is wired properly. Thanks for the replies.
02-26-2011, 03:08 PM
The solenoid will only click when it gets power. It should NOT get power until the trigger wire contacts a 12V source. IE the handlebar mounted toggle switch. If the solenoid is clicking just when hitting the starter the winch is either wired wrongly or have a crossed wire somewhere.
Get out your meter and start checking things...
02-26-2011, 06:25 PM
Member #11479
The solenoid clicks when I turn the key to ON.
02-27-2011, 09:08 AM
Member #2126
How old and what brand of winch is this. The older Warn's use a solenoid wired to the key switch which would click when the key was turned on. The newer ones do not do this and are wired so the engagement is with the in/out switch not the key switch. If it is a newer winch you might have to get the install instructions and begin "fixing" what the dealer did.
02-27-2011, 11:23 AM
Member #11479
This is a 2003 Warn winch.
02-05-2012, 06:41 AM
Member #22972
I have a 2004 Polaris 600 twin every time I hit my winch switch it clicks in the back from a black box took it apart couldn't see nothing wrong wasn't wet clean up all wires still clicking don't no what to change or fix please help point me in right direction thanks
02-08-2012, 10:30 PM
Member #22232
I bought my Bombardier in 03 and at that time Warn was giving away new style solenoid contactors because of fire problems with the old style. Might be worth checking out.
2011 850 X2, Smittybilt 3000 XRC winch. Front steel rack extension. Winch saver. Lock and Ride Windshield. 27 inch Zilla Tires. Moose Front Bumper. Remote Booster Cables. Quadovator Reverse Overide Switch. Polaris Plow. Rear A Arm Guards.
02-11-2012, 04:48 PM
Member #22972
Change contacktor still clicking hooked up booster cables and the winch works don't know what to do
2005 polaris winch only clicks, atv winch clicks but will not work photo how to clean a atv winch, atv winch solenoid clicks when key is switched on, how does winch solonoid work, how to tell if silanoid is bad on atv winch, is winch solenoid need to click to work, new atv winch just clicks, polaris 4500 lb winch not working, polaris winch not working, polaris winch selonoid, polaris winch solenoid click, polaris winch switch clicks, switch on atv winch just clicks, trying to use winch on atv and just clicks, warn atv winch solenoid clicks when key is turned on, warn wench only clicks when turned on, where is solenoid located bombardier winch, winch clicks, winch not turning solenoid clicking, without solenoid for atv winch
