09-20-2009, 09:12 AM
Member #1453
96 4x4 425 magnum battery not charging
I need some help,
I have a 1996 425 magnum 4x4 and my battery is not charging what do I check and do. please help
T.S.
09-20-2009, 06:18 PM
Member #767
425's should have an "LR" module that works as a voltage regulator. I've seen more of these go bad before a stator will. Not a good way to test them other than smell for burn. Or put a new one in and check voltage at the battery to check for a difference. Let me know how it turns out.
12-24-2009, 11:22 AM
Member #2398
Hi
I have just got a a magnum 425 and have the same problam, did you fix yours?
12-24-2009, 03:58 PM
Member #2326
The module is located behind the front bumper on the left side. Check all your wires for good connection. There is a problem with this Voltage Regulator going bad but I guess I just lucked up and found a bad wire that was pinched.
98 Trail Boss 250
94 400L 4x4
2007 Hawkeye 300
YouTube Channel: www.youtube.com/user/tinkerman01
1995 polaris 4x4 charging voltage, 1995 polaris magnum not charging, 1996 polaris magnum 425 voltage regulator, 425 polaris magnum not charging, 97 polaris magnum 425 chargeing system, 97 polaris magnum 425 charging system, battery for 1996 polaris magnum, how to check the charging system on a 96 polaris, how to test stator on polaris 425 magnum, polaris 425 battery connections, polaris 425 magnum battery, polaris 425 magnum chargeing, polaris 425 magnum charging system, polaris 425 magnum not charging, polaris 425 not charging, polaris magnum 425 no charge, polaris magnum 425 not charging, polaris magnum charging problems, reason for battery not to charge on polaris 425 magnum, what size battery goes in a 1996 polaris 425
