1999 Sportsman 335 Spark Problems - Polaris ATV Forum
post #1 of 13 (permalink) Old 02-27-2011, 02:51 PM Thread Starter
collins5637's Avatar
Hello, I have a 1999 335 4x4 that only gets fire at the plug the first spark then it will not fire again. If I keep hitting the ignition button and letting off it will keep firing. I just put a new Stator on this bike and thought that would fix my problem but no such luck, any help would be GREAT. Thanks.
collins5637 is offline
post #2 of 13 (permalink) Old 02-27-2011, 10:07 PM
Bruce! is offline
post #3 of 13 (permalink) Old 02-28-2011, 08:17 AM
Hit.The.Gas's Avatar
There is a black wire that has a spade connector and comes out of your CDI. unlplug this wire, this will eliminate your kill switch, keyswitch, and ETC. If you still don't have spark let me know! ~Phil
Hit.The.Gas is offline
post #4 of 13 (permalink) Old 02-28-2011, 04:05 PM Thread Starter
I tried disconnecting the black wire and it would not fire at all when I took it off, once I put it back it still would only fire the first time then no more. Any help is appreciated!!!
post #5 of 13 (permalink) Old 03-01-2011, 06:09 AM
I'm going to take a educated guess and say that you have a ground problem. Make sure your ground cable from engine to frame is still in good condition then make sure your stator has a good ground. ~Phil
post #6 of 13 (permalink) Old 03-02-2011, 05:00 PM Thread Starter
I checked both grounds you said and they were fine, any other suggestions, I know some people have had issues with their speedometer so I tried unplugging it also but no luck.
post #7 of 13 (permalink) Old 03-02-2011, 06:43 PM Thread Starter
Could the stator have taken out my CDI box or anything like that, if so is there a way to check it before I buy one? Teh only reason Im asking that is when I changed the stator out the wires going up to the wiring panel had be cut and corroided up. I didnt know if that would've shorted something else out. Before I changed the stator I was getting spark everytime but a really weak one.
post #8 of 13 (permalink) Old 03-03-2011, 05:06 AM
Yes, it is possible some CDI wires could have shorted out and caused the CDI to go bad. We probably have a used CDI for your bike if you believe that is the problem. Let me know! ~Phil
post #9 of 13 (permalink) Old 03-03-2011, 05:20 PM Thread Starter
How much?
post #10 of 13 (permalink) Old 03-03-2011, 05:34 PM Thread Starter
I was also told that it might be my speedometer, the guy said to un plug it and then unplug the wires on the main "box" to reset it. I dont knopw what he meant by the main box but if anyone has any help please let me know. Also I have been trying to use a jump box on my battery because its bad, would that have anything to do with it?
1999 250 Trailblazer - No spark - HELP! 1999TRAILBLAZER Polaris Trail Blazer 9 10-03-2015 04:20 PM
1999 Scrambler 500 No spark Costjohj ATV Repair and Maintenance 2 06-21-2011 08:12 PM
1999 polaris speedometer problems mickvn ATV New Members 4 11-17-2010 10:45 AM
1999 Sportmans - No spark Doc25 ATV Repair and Maintenance 1 04-20-2010 09:40 AM
1999 250 Trailblazer - No spark 1999TRAILBLAZER ATV Repair and Maintenance 4 11-04-2009 01:10 PM
