1993 Trailboss electrical issue - Polaris ATV Forum
View Poll Results: What do you think is wrong with this picture?
Ignition 1 50.00%
Voltage Regulator 0 0%
Stator 0 0%
Other 1 50.00%
Voters: 2. You may not vote on this poll
post #1 of 7 (permalink) Old 03-01-2011, 07:27 PM Thread Starter
TrailBo55's Avatar
I have a 1993 Trailboss 350 4x4 here. 2 Stroke liquid cooled model, with PVT drive. I noticed my battery isnt charging. When I unplug the positive terminal, I lose all lights, winch, all electrical basically. Engine stays running however.
Also noticed that I can start the bike without turning the ignition on. I dont know what is going on... Ignition problem? Voltage regulator? How to test these? I dont have a service manual. Manuals here on this site arent listing my year, or model unfortunately
Well Thats about all for now, any replies would be greatly appreciated. Thanks!!!
TrailBo55 is offline
post #2 of 7 (permalink) Old 03-02-2011, 06:07 AM
Bruce! is offline
post #3 of 7 (permalink) Old 03-02-2011, 07:16 AM Thread Starter
TrailBo55's Avatar
Thanks Bruce! !
Something I forgot to mention... The bike runs without the ignition set to ON, however the lights and electrical still shut off with the ignition set to OFF. Ignition off = no electrical, ignition on = electrical so long as battery is connected and charged. Tested with a volt meter, battery is not receiving a charge from the bike, and drains slowly when in use. If I disconnect the battery, the bike runs, but no lights, no power to winch, tail light, heck even the reverse light wont illuminate.
post #4 of 7 (permalink) Old 03-03-2011, 04:22 AM Thread Starter
TrailBo55's Avatar
anyone? Please?
post #5 of 7 (permalink) Old 03-18-2011, 05:03 PM
big4x4mudder's Avatar
To kill the engine the magnito (wrong spelling I'm sure) needs to ground out so I would check for a bad ground wire. (broke, loose, or conection needs cleaned up)
Ride it like you stole it!
94 sportsman 400 SOLD
01 sportsman 400
?? 110 Quadzilla
big4x4mudder is offline
post #6 of 7 (permalink) Old 04-08-2011, 01:59 PM
gsbeers's Avatar
First guess would be a bad ignition switch...but they are pretty hardy. My guess is that you may to end up with an electrical schematic of that unit trying to find out where someone messed with it. big mudder is right. the magneto is not grounding when you turn the ignition off start at the switch and work backward on the brown wire
gsbeers is offline
post #7 of 7 (permalink) Old 04-09-2011, 07:32 AM
yetavon's Avatar
test your voltage reg and charging system....all your electrical connections and grounds....use and ohm meter to double check your harness for broken wires...then try replacing the CDI Unit.....thats the point I'm at with my 97 Sportsman.
Darrin
yetavon is offline
1993 TrailBoss 250 oil injection help needed bobbyg ATV Repair and Maintenance 8 04-18-2015 02:11 PM
Polaris 1993 trailboss 250 Chadiusdotcom ATV Repair and Maintenance 8 03-31-2011 07:59 AM
1993 Polaris Trailboss 350 running issues unknown1329 ATV Repair and Maintenance 6 03-23-2010 09:27 AM
1993 OR 1994 Trailboss 350 Reverse Problems unknown1329 ATV Repair and Maintenance 2 03-16-2010 11:31 PM
electrical issue mrmd345 ATV Repair and Maintenance 6 01-11-2010 11:52 AM
