03-03-2011, 06:30 PM
Member #12596
2008 Polaris Sportsman 500 EFI HO fuel tank vent line ??? please help...
I have two lines leading into the area behind the top headlight assembly on the steering column. Both lines are clear plastic approximately 1/4 inch thick. (similar to fish tank tubing) Both lines lead to a T valve. Two ends of the T valve have check valves on them, and one end of the T valve is open. It's a long story however, I have the T valve all mixed up.
One line leads from the fuel tank for sure. I believe it is a vent line for the fuel tank. I think that goes to the check valve for sure. However, which way should I have the check valve? Air going into the fuel tank? Or air venting out of the fuel tank?
The other line comes up from inside the steering column to the T valve. I'm not sure where this line is going to or coming from. Do I hook this to the check valve or the open end of the T valve? If I hook it to the check valve, which way do I have the air going? Down into the line or out of the line?
I have called 5 different dealers and gotten 5 different answers. I called Polaris, and they told me to call a 6th dealer.
Any help would be greatly appreciated. Thank you in advance.
03-03-2011, 06:38 PM
Member #5629
Out of the tank. JMO
Con
03-03-2011, 09:50 PM
03-03-2011, 10:15 PM
Member #6542
Go to partshark.com and download the 2009 500 XP service manual. Look at the top of page 4.9.
_______________________
2010 Polaris 850 XP, Warn XP-30 Winch, KFI Winch Mount, Steel Front & Rear Rack Extenders
My neighbor called the cops because I was playing Radar Love too loud.... they arrested him.
07 sportsman gas tank vent, 2008 polaris sportsman 500, 2008 polaris sportsman 500 efi, 2008 polaris sportsman 500 efi repair manual free download, 2008 polaris sportsman 500 gas line, 2009 polaris 800 sportsman ho gas tank vent, 2012 polaris sportsman 500 clear fuel lines, 500 polaris sportsman fuel tank, fuel in oil polaris 500 efi, gas shutoff on 2008 polaris sportman 500 efi, gas tank vent on sportsman 700 check valve, how big are the gas tanks on a polaris sportsman 500, how big is the gas tank on a 2008 polaris sportsman atv?, polaris fuel cap sportsman 500 vented, polaris gas tank vent lines, polaris ranger 500 efi fuel filter, polaris sportsman 50 ho fuel line, polaris sportsman 500 fuel problems, polaris sportsman 500 fuel vent line, sportsman 500 ho fuel tank vent
