  #11 (permalink)
Old 03-22-2011, 04:18 PM
dirtywhiteboy's Avatar
Member #12807
Originally Posted by robertcwilkins View Post
Well I got it all figured out today, I adjusted the screw back to 2.5 and works like a champ now. Now i took the starter to realize that it needs to be rebuilt, all brushes are broke, thus making it now work. Just too bad that i had to remove clutch to get to starter. On top of this my pull recoil rope broke having to replace that too.
yeah,..i got 2 starters for my 400,..both work on bench,click on bike,...both probably need a rebuild,...my recoil was bad too,found a used one for 15 bucks,..polaris parts are high on the recoil an its a big big pain to try to put one together!!! that spring is a witch!!!! might not be too bad to just put rope back in it just make sure you preload reel before puttin rope on it!!
  #12 (permalink)
Old 02-07-2012, 11:35 AM
tcates33's Avatar
Member #13153
No gas
Hi All,
I have a 87 trailboss replaced the broken petcock and when all the hoses and filter are hooked up connot get any flow out of my petcock but if I disconnect the hose after the filter I get plenty of flow ever heard of this problem and also there is no kink in the tubing going to the carb.
Thanks for your help !!!
1987 polaras clutch removel
1987 polaris atv parts list
1987 polaris trail boss 250 fuel line schematic
1987 polaris trail boss 250 manual
250 trail boss adjusting oil pump
adjust clutch brake on 1987 polaris trail boss
brakes on 1987 trailboss
bypassing oil pump on 2 stroke atv good or bad
common 1987 polaris trail boss issues
how do i set the carb choke on a trail boss
how does the choke work on 1986 polaris trail boss?
how to adjust clutch polaris trail boss 250
how to put a 1987 polaris trail boss in to 4x4
how to replace throttle cable on polaris 250 trail boss
how to set up carburator on a 1987 250 trail boss
how to take the starter off an 1987 polaris traliboss
online repair manual for 1987 polaris trail boss 250
polaris 250 r/s choke pull
polaris trail boss 250 dies when hot
powered by vbulletin 1987 idler arm
WTB Swing Arm for 1987 Trail Boss 250 4x4 laegion ATV Parts for Sale 2 10-22-2010 03:35 PM
Carb questions 1987 250 trail boss Tiny ATV Repair and Maintenance 2 05-16-2010 12:46 PM
1987 trail boss spikeman ATV Repair and Maintenance 14 04-09-2010 06:38 PM
1987 trail boss 4X4 brake issues.... xpsfisherman118 ATV Repair and Maintenance 2 03-20-2010 06:04 PM
1987 Polaris Trail Boss 4X4 brake problems xpsfisherman118 ATV Brakes & Suspension 1 03-13-2010 04:59 PM
