03-10-2011, 05:20 PM
Member #12833
Trail Boss 250 1987 Question
I recently purchased a 1987 Trail boss 250 4x4 2-stroke in rough condition. I am attempting to redo everything on it and came across a problem. At first when i press throttle completely down it would smoke really really really bad and die out. So I adjusted the linkage for the oil pump to lean it out. Now i still press the throttle down a little farther but and it still dies out. So do i need to adjust the throttle side of the cable more to limit the fuel or the screw one the side of the carb? Im kinda at a loss with it cause its two stroke and oil injected. So long as i dont go full throttle its ok. Course it wont stay idling unless i keep it pushed. Any sugguestions? For me its different because when i rejetting my other atv i had some general guide lines, ie, 1.5 turn out one screw etc.
03-10-2011, 06:17 PM
03-10-2011, 09:18 PM
Member #12807
not that i have a clue bout atv carbs but you may find some info here...
Common Carb Issues
03-11-2011, 04:44 AM
Member #12833
Thanks for that link that answers some of the questions, I just need to experiment more with it now.
87 Trail Boss 4x4
Digital Camo Paint
Baja Fog Lights
Needs a battery
Starter Broke, BLAHHH
03-11-2011, 05:41 AM
Member #3330
Robert,
Nice lookin 87..
I think it is all in your carb. Take it apart and use speaker wire to clean out all jets and ports. It took three times to get mine to quite doing the exact same thing.
Craig and Paula
OP KS\Truman Lake MO
97 400 Sport (Hornet)
87 250 Trailboss (Devil)
03 Kaw 250 Bayou (Tonka)
86 Suzuki lt230ge (Blacky)
03-11-2011, 06:15 AM
Member #9741
yes clean the shit outta the carb...check the airbox..new air filter new plug... make sure the boot between the cylinder and the carb is not cracked(a crack will cause it to run like shit) new gas if not already and put the oil injection back to the way it was....(if it was original, theres no reason to mess with that...) try and find what factory adjustment is and put it there
2009 sportsman xp 550
hand and thumb warmers
pure polaris mid windsheild
pure polaris front bursh guard
warn 3500 winch
03-11-2011, 06:36 AM
Member #12833
Only other problem i have with it is the starter is frozen up. I bypassed the solienold and starter still wont turn over. I attempted to remove it but it appears that i have to remove alot just to get the bolts off the starter housing. It pull cranks fine after about five or six pulls. Also Im confused on the choke. I have a cable with a lever that appears to be choke. Its right nxt to key. If i pull the lever back during engine running it kills engine. So i never touch it. Is that the choke? Should it crank with it pulled then put it back to normal when idling? It will not crank if is pulled back. I dunno.
87 Trail Boss 4x4
Digital Camo Paint
Baja Fog Lights
Needs a battery
03-11-2011, 09:37 AM
Member #12807
yes,thats the choke,...an sound like its workin too!
03-13-2011, 05:21 PM
Member #12833
Well I got it all figured out today, I adjusted the screw back to 2.5 and works like a champ now. Now i took the starter to realize that it needs to be rebuilt, all brushes are broke, thus making it now work. Just too bad that i had to remove clutch to get to starter. On top of this my pull recoil rope broke having to replace that too.
87 Trail Boss 4x4
Digital Camo Paint
Baja Fog Lights
Needs a battery
03-22-2011, 03:53 PM
Member #13199
I have an 87 Polaris trailboss too it also dosnt run it needs a new piston and seals
1987 polaras clutch removel, 1987 polaris atv parts list, 1987 polaris trail boss 250 fuel line schematic, 1987 polaris trail boss 250 manual, 250 trail boss adjusting oil pump, adjust clutch brake on 1987 polaris trail boss, brakes on 1987 trailboss, bypassing oil pump on 2 stroke atv good or bad, common 1987 polaris trail boss issues, how do i set the carb choke on a trail boss, how does the choke work on 1986 polaris trail boss?, how to adjust clutch polaris trail boss 250, how to put a 1987 polaris trail boss in to 4x4, how to replace throttle cable on polaris 250 trail boss, how to set up carburator on a 1987 250 trail boss, how to take the starter off an 1987 polaris traliboss, online repair manual for 1987 polaris trail boss 250, polaris 250 r/s choke pull, polaris trail boss 250 dies when hot, powered by vbulletin 1987 idler arm
