My 2007 sportsman 500efi won't start - Polaris ATV Forum
post #1 of 6 (permalink) Old 03-11-2011, 11:45 AM Thread Starter
jaderhold's Avatar
Question My 2007 sportsman 500efi won't start
When you turn the key on the fuel pump kicks on and thats it. Battery is good just put new ingnition switch in cause I thought that was bad. The dash doesn't come on at all. All that works is fuel pump and winch. It was running then it just shut off. Any one have any ideas?
jaderhold is offline
post #2 of 6 (permalink) Old 03-11-2011, 11:55 AM
dodgeram3500's Avatar
Hey there, did you check the wire connections in the steering column?
Maybe water got in somewhere?
-2009 Polaris Sportsman 550 XP 3500lb. Polaris winch, Tall windsheild, Razor two way plow, rear rest box, and rear foot pegs. Our ATV
-1998 GMC Sierra 1500 4X4 extended cab with third door. My truck
dodgeram3500 is offline
post #3 of 6 (permalink) Old 03-11-2011, 03:55 PM
Bruce! is offline
post #4 of 6 (permalink) Old 03-14-2011, 09:58 AM Thread Starter
jaderhold's Avatar
yep did all that twice
post #5 of 6 (permalink) Old 03-21-2011, 12:01 PM
string69's Avatar
it should have a compartment under the headlight that snaps off, and should have 4-5 fuses check those then let us know
string69 is offline
post #6 of 6 (permalink) Old 03-22-2011, 02:00 PM
string69's Avatar
does your wheeler have the storage compartment under the front rack if so lift it up there should be a lid too a fuse box check the 5 amp fuse especially good it works the cluster good luck. just fixed one today doing the same thing it was a 500 sportsman probably the same.
string69 is offline
2007 Sportsman 500efi with Bumper question jsingraham Polaris Sportsman 7 02-15-2011 06:31 PM
Help with 09 sportsman 500EFI bigtex ATV Repair and Maintenance 3 09-23-2010 08:38 AM
2007 Sportsman 800 won't start... BagoXCAlum99 ATV Repair and Maintenance 5 08-15-2010 07:38 AM
Idle Problems 2007 Sportsman X2 500EFI Gecco2003 Polaris Sportsman 13 03-17-2010 06:08 AM
2007 Sportsman 500EFI Fuel Gauge jdonatini Polaris Sportsman 3 02-23-2010 10:52 PM
