500 Sportsman will idel but not rev up. - Polaris ATV Forum
Old 03-11-2011, 02:02 PM
dogmandino's Avatar
Member #12854
I have a Polaris 500 HO sportsman 4X4. Was riding one day and it just shut down on me. The crazy thing is, that it will start right back up and idle all day long but as soon as you try to give it gas it spits and sputters and dies. I have changed the CDI, Fuel filter, Throttle body with the MAP, and TPS. Still the same problem. I tried the trouble shooting to see if it might think it is in reverse gear. It has got me stump. If anyone has an idea I am willing to give it a try.
Thanks Dino.
Old 03-11-2011, 04:55 PM
Old 04-28-2011, 06:49 AM
rusty richard's Avatar
Member #14513
bump...got a similar problem on 08 500 efi...dies when throttle is wide open
Old 04-28-2011, 09:48 AM
Hit.The.Gas's Avatar
Member #11694
Fuel pump? Should have a decent amount of fuel pressure if its EFI. If not, I believe people have found Fuel pumps off hyandai sonata's that fit so you don't have to buy a complete tank from Polaris. ~Phil
Old 04-28-2011, 02:21 PM
polaris50007's Avatar
Member #13981
test
have U tried a campression test to see if the cam went flat? have had it happen in the past.Good luck,Mike
Old 04-28-2011, 02:34 PM
tt425's Avatar
Member #3687
I agree with you. If you are sure not bad fuel(water in fuel). Remove the valve cover and inspect the cam for exhaust lobe wear.
2008 Dodge Caliper
2010 Chevrolet Equinox
2004 Honda ForemanES 400 4x4
(Currently I don't own a Polaris but I work on them all the time and get to ride cutomers for test rides. Maybe soon I will be a Polaris owner.)
Old 04-28-2011, 03:31 PM
TinkerMan's Avatar
Member #1980
Exhaust lobe on the cam would be my guess ...not what you want to hear Im sure but if you pull the valve cover and the spark plug and turn the motor over the lifters should raise the same height if the front is less than the rear..Exhaust lobe is gone you'll need a new cam and rocker... Good luck! Todd Polarisatvrepair.com
Old 05-06-2011, 04:01 AM
dogmandino's Avatar
Member #12854
Polaris dies when the throttle is punched
My throttle was dieing after I would start the bike and let it idle. I found that there was lose connection on the EFI. Once I maid sure it was reconnected real good it ran like a champ. Have not had any more issues with it.
Old 05-06-2011, 04:02 AM
dogmandino's Avatar
Member #12854
ride hard but safe
Old 05-06-2011, 04:50 AM
cwlongshot's Avatar
Glad you found it!!! Stuff like that is super frustrating!!!! CW
2015 RZR 900 Trail BLK. Pearl
Lock N Ride roof
Lock N Ride 1/2 windshield
Lock N Ride rear box
LED lights front, top & rear
LOTS more coming...
1996 polaris 500 not revving up
2001 polaris 400 sportsman starts good but will not rev up
2001 polaris 400 sportsman will not rev up
2008 polaris ranger 500 efi won't rev up
500 sportsman wont rev up
polaris 400 sportsman will idel but not rev up
polaris sportsman 500 ho wont rev
polaris sportsman 500 idles wont rev up
polaris sportsman 500 wont rev up
polaris sportsman wont rev up
sportsman 500 idles but wont rev up
high idel diggs Polaris Scrambler 3 12-26-2010 01:02 PM
2001 Trailblazer high idel Nuworld Polaris Trail Blazer 6 09-11-2010 08:27 AM
