Wiring in a winch - Polaris ATV Forum
Old 03-26-2011, 05:01 PM
ddw304's Avatar
Member #12322
Wiring in a winch
Yes when wiring in a winch, on the egnition key switch wiring which wire do i wire in to the hot wire on a sportsman 800 2010, i dont have a tester. thanks david
Old 03-26-2011, 06:11 PM
chopper89's Avatar
Member #1634
polaris come prewired to the front of the machine for the winch, if you have your front fenders off its on the right side of the frame ,
2014 850 XP EPS BROWNING EDITION
POLARIS WINDSHIELD
POLARIS GUN CASE
ITP T7 BEADLOCK RIMS
ITP 27 XTR TIRES
RICOCHET A ARM GUARDS
________________________
Old 03-26-2011, 08:05 PM
pathfinder's Avatar
Member #10066
Pull off the cover that sits below the headlight pod on the column and you will find an orange wire with a white stripe on it, you will probably see two of them. Polaris leaves these wires hanging out of the wiring harness for aftermarket accessories( winches, lighting, etc.). Just have to hook into one of the orange and white stripe wires.
2010 Sportsman 500 HO
3 headlight mod (with relay)
rear rack extender
handguards
Warn XT25 winch
Ricochet arm guards(anodized black)
Polaris front & rear brushguards
LED tail lights www.autolumination.com
HID light kit http://www.theatvsuperstore.com/ATV-HID-Lights-s/54.htm
Old 03-26-2011, 08:18 PM
summer lynn's Avatar
Member #11405
Hey David spend $20 on a cheap mutimeter for christ sakes, you spent a whole lot more on the winch plus a ton more on the bike itself geez and it.s not like u won't need it in the future
Old 03-27-2011, 04:07 AM
Cableguy657's Avatar
Member #3405
along with a digital multimeter, one of these are nice to have. just hook up the lead to ground and you can test to see if you have 12volts, helpfull when looking for a switched circuit or if a fuse is good or bad.
Amazon.com: 6-12 Volts Heavy Duty Circuit Tester: Automotive Amazon.com: 6-12 Volts Heavy Duty Circuit Tester: Automotive
2013 RZR XP 900
Old enough to know better but, still too young to care!
http://s859.photobucket.com/home/cableguy657/allalbums
how to wire winch on polaris rzr 909
polaris 3500 winch wiring
polaris 3500 winch wiring diagram
polaris 800 winch wiring schematic
polaris ranger 500 winch installation
polaris ranger winch wiring diagram
polaris winch wiring
polaris winch wiring diagram
polaris.ranger.winch.wiring
rzr winch wiring diagram
winch diagram for 2006 sportsman
wiring winch on polaris ranger
super winch switch wiring ? napaman9 ATV Repair and Maintenance 2 01-23-2011 07:29 PM
Super Winch Wiring install Chopwood Polaris Sportsman 2 01-17-2011 07:14 PM
2010 850 viper winch wiring sportsman613 Polaris XP 3 01-16-2011 10:18 AM
winch wiring dnhaarre ATV Repair and Maintenance 4 12-08-2010 06:04 AM
Wiring a non-Polaris winch mjscharlotte ATV General Discussion 4 11-05-2010 07:02 PM
