97 magnum 425 4x4 questions need help - Polaris ATV Forum
post #1 of 5 (permalink) Old 04-05-2011, 09:35 AM Thread Starter
STEALTH3350's Avatar
1...hello this is my first atv so im a newbie so bare with me... How tight is the back chain sapost to be? I notice its a little loose?
2...the awd button lights up when pushed in. When put into neautral light goes off.. Normal??
3..is the awd sapost to be lit in reverse... 4x4 works when hold over ride button but no awd light???
4..the forward light and reverse light do not work? The neautral light flickes some times???
5... Speedometer does not light up bulb???
6...handle bar warmers work sometimes the button is mounted in the plastic on dash??
Please any info would help me better understand my atv.. Like i said this is my first atv
STEALTH3350 is offline
post #2 of 5 (permalink) Old 04-05-2011, 05:43 PM Thread Starter
Bump bump
post #3 of 5 (permalink) Old 04-05-2011, 06:05 PM
Bruce! is offline
post #4 of 5 (permalink) Old 04-06-2011, 05:17 AM
pjmartin's Avatar
The back chain is supposed to be loose because the suspension geometry tightens it when the suspension is compressed. Never adjust it unloaded. Put about 200lbs on the rear rack and then adjust the chain by turning the eccentric shaft carrier so the chain has 1/2inch total up and down movement.
AWD off in neutral is normal.
pjmartin is offline
post #5 of 5 (permalink) Old 04-06-2011, 07:20 AM Thread Starter
Thanks for info
First time atv owner.. 97 magnum 425 have a few questions.. Help please STEALTH3350 Polaris Magnum 4 04-17-2011 05:55 PM
97 magnum 4x4 loud sound and 4x4 questions barber878 Polaris Magnum 3 01-25-2011 10:57 AM
2000 325 magnum questions topdogeye Polaris Magnum 1 10-05-2010 03:30 PM
96 Magnum 425 6x6 fluid questions pvman ATV Repair and Maintenance 4 12-05-2009 05:29 AM
2001 500 magnum 4x4 questions cordoba11 ATV Repair and Maintenance 1 09-22-2009 04:44 PM
