fuel gauge reading empty when the tanks full, reverse lights not turning on... - Polaris ATV Forum
Old 04-08-2011, 06:03 PM
swampking's Avatar
Member #13812
Hey ,
i got a 08 sportsman 800, i filled up my tank today and noticed its still says empty, also when im in reverse the lights aren't turning on. could this be a simple fuse problem?
also noticed a slight knock kind of sound when i first hit the throtle. is this normarl?
Old 04-08-2011, 06:20 PM
Old 04-08-2011, 06:22 PM
First thing i would do is get a light and see if the float inside the tank is stuck...I cant remember exactly how the fuel gauage works, but i would look in there.
The reverse lights are not reverse lights unless you have made them that way. Did they have that mod before and now they are not working? Because if its stock, they wont turn on in reverse.
The knock is hard to say. It is a hollow knock, a ping, and clank,.....its just too hard to say
Old 04-08-2011, 06:29 PM
swampking's Avatar
Member #13812
the knock is coming from somewhere closer to the back more hollow the a ping or clank, id compare it to when my u joint was worn on my truck, makes the same noise if you've ever heard that before.
Old 02-25-2013, 12:58 PM
motormaster17's Avatar
Member #34365
The fuel sending unit has sliding gauge on it. First check the float. Then remove the entire fuel sending unit/fuel pump. look carefully at the sliding gauge. Make sure it touching the board. Make sure the coiled up wire is fine. Start their. Let me know how you made out.
carcsay im low fuel but i put gas in it
filled up gas tank and it says empty
filled up tank still says empty
i filled my own gas tank with a gas can why does my gas gauge still say empty
i filled up my tank and it still says its on empty
just filled up gas tank but it says i am empty
just filled up my tank and it still says its empty
just put gas in my car now reading empty
put gas in car but says empty
sportsman empty sais when full
why my car says its empty when its full
why would my gas gauge go in reverse when i turn it on a boat
08 800 sportsman fuel gauge not reading correctly Andrew85 Polaris Sportsman 11 03-22-2013 08:45 AM
Sportsman Fuel Gauge stuck on full? MandAtaco ATV Repair and Maintenance 8 02-18-2013 11:35 AM
Gauge stuck on full MandAtaco Polaris Sportsman 3 03-22-2011 02:08 PM
Turning Radius & Fuel Consumption of Touring 850 Dbez1 ATV General Discussion 7 01-07-2011 09:49 AM
fuel gauge pal95mon ATV General Discussion 2 12-27-2009 08:15 AM
