04-12-2011, 05:57 PM
Member #7502
'04 500 HO - what oil and where?
I am servicing my '04 Sportsman 500 HO that I just bought. I downloaded the Polaris owner's manual and it is vague and confusing.
The chart on page 76 says to use Polaris Premium Drive Hub Fluid. The description on page 84 says to use Polaris Synthetic Gear case Lube (80w-90 gear lube). What oil do I use and where the heck is the fill hole?
Same machine, the manual shows a transmission dipstick and fill port. I have looked and looked and cannot find this on my machine. Where do I fill the tranny?
Any help is appreciated! Thanks!
FYI - machine was born 10/03 so don't exactly know if it is an '04 or '04.5
04-12-2011, 07:00 PM
Member #13816
Your polaris probly takes 4 differant types of fluid, demand drive hub fluid, angle drive fluid, agl plus, and ps-4 plus, good luck and dont put em in the wrong hole.
2001 Polaris Scrambler 500 4x4 STOLEN At MJ USA
(2) 2003 Polaris Sportsman 90cc
2006 Polaris Predator 50
2006 Polaris Phoenix 200
2008 Honda Trx700xx
10-30-2012, 06:36 PM
Member #30988
Thanks smart ass. He was asking where each goes
10-30-2012, 07:50 PM
10-30-2012, 09:20 PM
Member #9235
Lube Chart for All Polaris ATVs
The dipstick for the tranny is on the right side. Look just forward of the axle kinda tucked back behind the rear brake caliper....you should see a round plastic piece. Mine is bright yellow. that's the dipstick and filler hole.
Do you have a lift? I jack mine up to do a full service. Much easier with the wheels off. Gives you better access to the grease zerks. Good investment.
02' Sportsman 500 HO
Warn 25XT + Bumper
25" Grim Reapers
GoldFinger left hand throttle
and other stuff...
04 polaris ranger 500 oil, 04.5 sportsman 500ho transmission fluid, 2001 polaris 500 ho 4x4 what tipe of oil, 2001 polaris 500 yellow dip stick oil tans, 2002 scrambler 500 4x4 agl plus synthetic gear case lubricant and transmission fluid, 2003 polaris 500 ho fluid amounts, 2003 polaris sportsman 500 wont go in to awd, 2006 polaris 500 scrambler transmission fluid, 2006 polaris scrambler 500 oil recommendations, polaris scrambler 500 oil type, polaris sportsman 500 2001 yellow dip stick in rear end, recommended oil for 2006 polaris 500 ho, what oil should i put in the transmission of a sportsman 2008 500ho, what type of gear lube should i run in my 2000 polaris scrambler 500 4x4, what weight of oil 99 polaris scrambler 500
