I drained the tranny fluid and tried to add new from the fill hole and I cannot get any fluid to go in. It drains out of the hole and none will go in the tranny.. I noticed that there is a spring in there does that have anything to do with it? I need some help plz.
The oil drains out of the tranny drain hole? Did you make sure the retaining washer was replaced? Could just be leaking from there. Make sure you don't over tighten that bolt to (as most people know on here how AVID I am about that bolt now) as to not have issues down the road later on.
What are you using to fill it? My oil came with a crappy fill nosel which made a mess. I think from now on I'm going to use one of those 10$ pumps that you use to fill the bottom leg of an outboard, they work great!
113.2K members
