Plastic repair? - Polaris ATV Forum
post #1 of 25 (permalink) Old 04-14-2011, 05:11 PM Thread Starter
sman700's Avatar
Plastic repair?
I have a broken plastic piece on my 05' Sportsman 700 and was looking for some ideas on how to repair it without buying the whole assembly. The broken piece is part of the rear body assembly and is under the seat, picture is attached to help illustrate.
I was thinking about trying to use a plastic welding kit to fix this. Has anyone tried this? Or have any other ideas?
Any feedback from experience would be helpful.
Name:	atv rear body 1.jpg
sman700 is offline
post #2 of 25 (permalink) Old 04-14-2011, 05:30 PM
atvman2010's Avatar
not sure how nice you want it to be and look but on my broken plastic i sort of stitched it. i drilled holes on each side of the crack and zip tied it together.
2002 polaris sportsman 700 twin 4x4-rear cargo box
-freshly rebuilt top end
2003 polaris trailboss 330 2x4-freshly rebuilt engine
1987 Yamaha Banshee 350 twin (sold)
1998 Yamaha badger 80 (sold)
1993 arctic cat 550 ext! (snowmobile)
atvman2010 is offline
post #3 of 25 (permalink) Old 04-14-2011, 05:47 PM Thread Starter
sman700's Avatar
Doesn't have to be real pretty. It is covered by the seat. I was just looking for it to hold together, maybe going to try one of those cheap plastic welding kits from harbor freight.
sman700 is offline
post #4 of 25 (permalink) Old 04-14-2011, 09:02 PM
grub's Avatar
I've got the same exact break on my 800. I drilled it and used safety tie wire. Not sure if it will hold up to the vibration, but we'll see. If not I'll try plastic zip tie next. I've never used the plastic welding kit so get back to us after you've used it for a while.
2005 Sportsman 800 EFI
grub is offline
post #5 of 25 (permalink) Old 04-14-2011, 09:40 PM
black sparrow's Avatar
Try drilling small holes and use small gauge wire to sew them together then put plastic welding kits/epoxy on top and bottom of it to seal them together. You might able to sand it if its small enough and paint over it.
My 2 cents.
"To EaCh hIs oWn"
black sparrow is offline
post #6 of 25 (permalink) Old 04-14-2011, 09:53 PM
MNPolaris850XPeps's Avatar
^^ thats what id try ^^
POLARIS 850 XP W/EPS pure polaris hand guards and front lock and ride box, RICOCHET front and rear a-arm gaurds all lifted up on 27" GBC SPARTICUS tires on ITP system 6 rims, uni air filter and fender flares on the way
MNPolaris850XPeps is offline
post #7 of 25 (permalink) Old 04-14-2011, 09:54 PM
mn800r's Avatar
Plastic epoxy at any auto parts store..
mn800r is offline
post #8 of 25 (permalink) Old 04-15-2011, 03:02 AM
cwlongshot's Avatar
Its small, but be sure to drill a small hole at the end of the crack to stop it from going further...
The plastic weld lit altho seemingly cheap, can work very well. My buddie has fixed his kids fenders most of last year with one. One time he tore it right off and the kit with a little wire for good measure and out of site fixed it up very nicely...
2015 RZR 900 Trail BLK. Pearl
Lock N Ride roof
Lock N Ride 1/2 windshield
Lock N Ride rear box
LED lights front, top & rear
LOTS more coming...
cwlongshot is offline
post #9 of 25 (permalink) Old 04-15-2011, 12:45 PM
kerchie1's Avatar
Oh Yea, This is for you.
I recently ran across something called Marine Tex. It has not one time let me down and I'm talking repair as fine as eyeglass frames to molding and actually fabricating machine parts. It can be applied as thin as 1/32 and as thick as 1 1/2 inches. You can mold it like clay or spread it like butter pending on your needs. I've used it on glass, ceramic, plastic,metal, fiberglass and once even made me a temporary new boot sole. They even have one that remains flexable and one that can be applied completely underwater. Solvents grease and oil don't effect it and get this it even adheres to polypropelene or whatever that
plastic is that nothing sticks or bonds to (such as radiators)
It mixes like an epoxy (2 parts) Give it a try and I'm sure you'll be as sold on it as I am. After all this ranting on can you believe I'm not affilliated with it in any way what so ever other than just a consumer.
kerchie1 is offline
post #10 of 25 (permalink) Old 04-15-2011, 01:59 PM
icefishur96's Avatar
My 07 500 is also broke in the same spot. I just drilled out 5 small holes, and used my safety wire pliers to spin them up tight.
2000 Scrambler 90
2008 Sportsman 500 H.O. EFI
2011 RZRs LE
Accessories from www.TheATVSuperStore.com
icefishur96 is offline
Mending Plastic Back Together...Nedd Help Fixing Cracked Plastic Bama450er ATV Visual & Body Modifications 7 10-07-2010 05:30 AM
where to buy new plastic ? krazybob Polaris Scrambler 0 08-16-2010 10:05 AM
looking for rear plastic odie22 ATV Parts for Sale 0 06-13-2010 05:02 PM
New Plastic jpbiggs Polaris Sportsman 4 04-04-2010 10:00 AM
Need Plastic! 07 Pred500 ATV Parts for Sale 0 03-31-2010 08:14 AM
