Oil change 2011 Sportsman 500 - Polaris ATV Forum
post #1 of 6 (permalink) Old 04-17-2011, 04:12 AM Thread Starter
Warhorse's Avatar
Reading the owners manual about oil changes on my new 2011 Sportsman H.O. it say that after I change the oil and filter, fill with two Qts. oil, that I need to clamp off the line that runs from the oil tank to the pump, start the engine, let it run for about 20 seconds and release the clamp, and that I should hear a rush of air, if not, repeat the procedure.
Talking to others who own older machines, they never heard of such a thing.
What's up with this?
Warhorse is offline
post #2 of 6 (permalink) Old 04-17-2011, 04:31 AM
bgirard420's Avatar
You only need to prime the pump if you remove the filter screen that goes from the reservoir to the oil pump. This "re-pressurizes" the system so to speak. BTW, it is not the hose from the reservoir to the pump that you clamp (that would be bad), it is the vent line with a 2 inch slit in it at the very top of the pump that runs to your airbox.
You only need a full 2 quarts if you empty the crankcase as well (I guess some people don't routinely do this since it's a bit of a pain in the balls but I didn't think it was too bad.) I empty everything, plus that crankcase collects all the debris at the bottom, so why not drain it. Hope this helps.
2013 Polaris XP 850 HO LE EPS
2010 Polaris 500 HO
bgirard420 is offline
post #3 of 6 (permalink) Old 04-17-2011, 06:46 AM Thread Starter
Warhorse's Avatar
Thanks for that info!
Warhorse is offline
post #4 of 6 (permalink) Old 04-17-2011, 07:27 AM
bgirard420's Avatar
No problem, first change takes a little longer since it's all new. Did you see this video, it's pretty well representative of what it's like. Good luck.
2010 Polaris 500 HO
post #5 of 6 (permalink) Old 04-17-2011, 09:22 AM
NineLives's Avatar
After I change my oil I pinch the return line from the engine to the tank with my fingers and you should feel a pulse which is the oil returning to the tank. That way you know for sure that the system is properly primed. As stated above you only need to prime if you clean the pickup screen but I always check just to be safe.
NineLives is offline
post #6 of 6 (permalink) Old 04-19-2011, 01:28 PM
icefishur96's Avatar
Boy, He was in a hurry!!! And his wife is going to be pissed if she finds that nice towel full of oil!!! Yes I am talking from previous experience!
2000 Scrambler 90
2008 Sportsman 500 H.O. EFI
2011 RZRs LE
Accessories from www.TheATVSuperStore.com
icefishur96 is offline
How to change coolant on a 02 sportsman 400 chillmouser ATV General Discussion 3 12-26-2010 09:11 AM
Sportsman 500 oil change bigbike ATV Repair and Maintenance 2 11-13-2010 05:51 AM
2005 sportsman 500 oil change ? model70 ATV Repair and Maintenance 3 03-13-2010 04:51 PM
08 Sportsman 500 oil change??? kdsberman ATV General Discussion 11 12-20-2009 06:03 AM
Oil & Filter change 500 Sportsman 08 newrider ATV General Discussion 4 10-01-2009 05:50 PM
