Old 10-12-2009, 10:46 AM
bigblue's Avatar
Member #1658
1997 polaris Scrambler 400 will not go into forward gear!
I am new her but looking forward to looking around! So here is my problem I have a 97 scrambler 400 and it will not go forward. Reverse works fine but when i shift it into forward it just sits there, it just happened the other day, up until then it ran fine. Any ideas where to start trouble shooting or what is wrong?
Old 10-12-2009, 01:27 PM
4getful2's Avatar
Member #1234
you did check your linkage ?? or unhook the shift rod at the front linkage and give it a push to the rear,that should be forward gear. any grinding or snapping??
Old 10-12-2009, 02:08 PM
bigblue's Avatar
Member #1658
Yea the linkage is ok but the seems to be a grinding! I just got it up on the stand and when u push in into forward the back wheels move forward like it is trying to go but that is it.
1997 polaris 400 shifter
1997 polaris 400 wont go forward
1997 polaris scrambler 400
1997 polaris scrambler gearbox
2000 polaris scrambler 400 wont stay in gear
atv will only move in reverse forum
atv will shift into reverse not forward
my polaris 400 wont go in forward but will go in reverse
my polaris atv will only go in reveres
polaris 400 scrambler wont go into gear
polaris 97 400 wont go in gear
polaris atv doesnt move in any gear
polaris atv will not go into gear
polaris runs but will not go in gear
polaris scrambler 400 issues
polaris scrambler 400 its not going on reverse
polaris scrambler 400 shift problem will not go in gear
polaris scrambler 400 vs honda 400
polaris scrambler 400 will not shift into forward
polaris scrambler not going into gear
