rear prop shaft removal - Polaris ATV Forum
post #1 of 9 (permalink) Old 04-24-2011, 01:15 AM Thread Starter
bignicker's Avatar
Red face rear prop shaft removal
I have a 2000 xpedition 425 that has a bad u joint on the rear prop/drive shaft but I can not figure out how to remove the shaft I removed the roll pin but the shaft does not slide back far enough to remove it from the splined shaft coming out of the engine
bignicker is offline
post #2 of 9 (permalink) Old 04-24-2011, 04:56 AM
Bruce! is offline
post #3 of 9 (permalink) Old 04-24-2011, 05:24 AM
Trailblazersonny's Avatar
Sorry not familiar with that bike. Sounds like trans or rear diff will have to be loosened and slid back. I have had to do that on other machines just not a Polaris.
TBS
2009 Sportsman 550 XP EPS
Polaris Lock n Ride Hard Case
Rotopax Fuel Tank
ATV Guru Front Brush Guard
Trailblazersonny is offline
post #4 of 9 (permalink) Old 04-24-2011, 05:50 AM
racer37l's Avatar
Welcome!
You will have to slide the rear diff back to remove the propshaft.
Con
racer37l is offline
post #5 of 9 (permalink) Old 04-24-2011, 06:06 AM Thread Starter
bignicker's Avatar
Thanks thats what I was afraid of
post #6 of 9 (permalink) Old 04-24-2011, 06:35 AM
racer37l's Avatar
It's not that bad! Just takes a little time!
When you go back with remember to tighten the bottom bolts first after getting all the bolts started!
Good luck!
Con
racer37l is offline
post #7 of 9 (permalink) Old 04-24-2011, 10:33 AM Thread Starter
bignicker's Avatar
Thanks the worst part is I just had the rear end apart to change the axle bearings what a pain that was those bearings were 11 years old and toasted I think I will try and take that prop shaft out this weekend I will let u know how it goes
post #8 of 9 (permalink) Old 04-27-2011, 09:39 AM Thread Starter
bignicker's Avatar
Well got the prop shaft out damage and back in I had to pull the whole rear end out but it wasnt as bad as I thought took maybe an hour to pull rear end and shift and change out u joint and reinstall thanks again for your help guys
BIGNICKER
2000 xpedition 425
3000 lbs venom winch
front and rear tube bumpers
27" goodyear mudrunners
60" cycle country plow
post #9 of 9 (permalink) Old 04-27-2011, 05:33 PM
racer37l's Avatar
Your welcome!
Con
racer37l is offline
prop shaft removal rifleman24 Polaris Sportsman 42 09-27-2014 01:42 PM
rear drive shaft removal 304ronnie ATV Repair and Maintenance 8 08-26-2011 11:18 AM
Rear Prop Shaft Turns -- Rear Wheels do not fz1oakville ATV General Discussion 2 02-25-2011 12:32 PM
Front Prop shaft removal rifleman24 ATV Repair and Maintenance 0 11-08-2010 06:26 AM
05 ranger 6x6 rear prop shaft. pafree ATV Repair and Maintenance 0 01-20-2010 08:04 PM
