rough idle/stalls - Polaris ATV Forum
Old 04-24-2011, 12:21 PM
chevyman_12's Avatar
Member #10019
Question rough idle/stalls
just rebuilt my 97 trailboss 250 carb. no improvement. still will only keep running with choke on and idles hard. when choke is removed, the idle will smooth out for a few seconds then die. will only start with help of starting fluid. has oil block off and 40:1 fuel. any suggestions? i'm lost. i have the idle air screw 1.25 turns out. thats all i know to set. no idea why its running so rough. need help.
Old 04-28-2011, 08:28 AM
Member #10019
ok i got it running now. will start on choke pretty good and runs off choke fine. has a little hesitation. to get it running i had to turn the idle screw all the way in and have the idle air screw out only half a turn. any ideas whats wrong with it? is the carb just wore?
Old 04-28-2011, 09:43 AM
Hit.The.Gas's Avatar
Member #11694
Check compression, and if compressions good I would replace the crankseals. It doesn't sound like it has good suction, it's having trouble pulling fuel into the combustion chamber. ~Phil
Old 05-06-2011, 06:40 AM
Member #10019
how do you change the crank seals? do you need to pull the whole engine and tear it all down? or is there an easy way?
Old 05-07-2011, 06:06 AM
Trailblazersonny's Avatar
Member #13864
What did the compression test show? Anything under 100 its top end time.
Should pump 120.
TBS
2009 Sportsman 550 XP EPS
Polaris Lock n Ride Hard Case
Rotopax Fuel Tank
ATV Guru Front Brush Guard
2000 polaris sportsman 335 wont idle
2010 polaris atv runs ok for awhile then dies and idle rough
atv idles rough
atv idling rough
atv misses at idle
atv rough idle
polaris 120 won't idle
polaris 120 wont idle
polaris 335 wont idle
rough idle sportsman 335
trail boss stalls without choke
when i turn the idle screw on my polairiscyclone 250 the idle does not change
2007 500 EFI stalls out at idle ski50007 Polaris Sportsman 5 06-03-2012 02:59 PM
rough idle halfa12pk ATV Repair and Maintenance 1 02-26-2011 05:12 AM
Sportsman 800 Running ROUGH/Won't Idle Dempsey7 ATV Repair and Maintenance 3 12-16-2010 04:04 AM
2006 Sportsman 500 HO stalls at idle Randydede ATV Repair and Maintenance 3 05-31-2010 10:16 PM
2006 Sportsman 500 HO stalls at idle Randydede Polaris Sportsman 0 05-31-2010 08:03 PM
