10-15-2009, 07:29 PM
Member #1635
08 Sportsman 800 EFI Fan Circuit Breaker HELP!!
Could someone give me specific instructions on how to locate the fan circuit breaker? The fan has not been running so I disconnected the thermistor wire and the fan still didn't some on. I would like to check the fan circuit breaker but I can't find it. I would also like to konw how to test the fan relay to see if it's functional.
01-23-2010, 11:20 AM
Member #2556
If you disconnact the thermo wire the fan should come on. The circuit breaker should be located under the front of the headlight pod, just take the cover off in front and below it. It will be wrapper up in rubber like a bike tube material. It's half the size of a 9 volt battery and has two wires going to it and has two bolt like connections on it. I couldn't find one to replace mine with so I just changed it to use a fuse and have had to change the fuse a few times. Let me know if your still having troubles finding it
04 polaris hot engine sensor, 2008 polaris sportsman 800 efi fan circuit breaker, 2009 polaris sportsman fan circuit breaker, 2010 polaris ranger 800 replacement fan, blastern sportman 800 were is relay breaker located at, circuit breaker polaris sportsman 800, how to test a circuit breaker on an atv, polaris 2x4 ranger 2004 circuit breaker, polaris 800 efi circuit breaker, polaris circuit breakers, polaris fan circuit breaker, polaris ranger fan circuit breaker, polaris ranger thirmistor location, polaris sportsman 800 breakers, polaris sportsman 800 fan circuit breaker location, polaris sportsman circuit breaker, polaris sportsman circuit breaker location, polaris thermistor, sportsman circuit breaker, where is the circiut breaker for the fan located on a polaris sportsman 800?
