1996 Xplorer 400 Speedometer not working! - Polaris ATV Forum
Old 05-01-2011, 07:38 AM
MNTravis's Avatar
Member #14616
I have a 1996 Xplorer 400 in great shape except the Speed-o doesnt work. To troubleshoot it I disconnected the speedo cable from the transmission and hooked up to a drill. It spun up just fine and the speedometer/odometer worked correctly. So therefore it looks like the problem is in the transmission or the hook-up point to the transmission.
I have looked at the microfiche and just cant find the fiche that shows the connection of the speed-o cable to the transmission?!?!?? It looks just like the speed-o connection on my Polaris snowmobiles (I think they re-use lots of parts between models and even ATV to snowmobile). Can anybody post a link to the microfiche for this part?? I am trying to get the part number for the hub that the speedo cable hooks up to, which in turn is bolted to the left side of the transmission by three bolts.
Second, whats the chances that the bolt on part is the problem and not something internal in the transmission?? Really want to have a working speedometer/odometer, but not planning on pulling and cracking open the entire transmission if that is where the problem lies!
Thanks for any help!
Travis
1996 Polaris Xplorer 400
Old 05-01-2011, 08:23 AM
pjmartin's Avatar
Member #5074
Send a message via ICQ to pjmartin
Browse
I think it's listed under the pod parts. It's a right angle drive. You can probably test it by removing it from the side of the transmission without taking the transmission apart.
Old 05-01-2011, 08:30 AM
MNTravis's Avatar
Member #14616
Yep, for the next guy (if any) the parts are:
3280218 Drive Adapter
3280217 Seedo Drive key
5020741 Bushing Speedo drive
BTW, it is listed under the headlight microfiche, who would have thought?? I am going to replace all the parts just to make sure it is done right. $47.19 with shipping for all of it through various sources on eBay.
1996 polaris 4x4 sportsman 400 change speedometer drive
1996 polaris 4x4 sportsman 400 change speedometer drive#gsc.tab
1996 polaris sportsman 400 speedometer
1996 polaris xplorer 400
1996 polaris xplorer 400 speedometers for sale
96 polaris speedometer stopped working
how to fix my polaris xplorer speedo drive unit
how to fix speedometer on a polaris xplorer
polaris xplorer speedometer
polaris xplorer speedometer not working
speedo not working on my polaris xplorer
1996 xplorer 400 runs poorly tasertotts ATV Repair and Maintenance 5 11-06-2013 04:14 PM
Polaris XPLORER 300 (W969130) 1996 SkroMcNail ATV Repair and Maintenance 2 03-21-2011 09:25 PM
Tach for a 1996 400 xplorer adamd Polaris Sportsman 1 03-02-2011 12:13 PM
500 magnum 4x4 quit working along with speedometer wornouthorse ATV Repair and Maintenance 2 12-10-2010 05:56 PM
1996 magnum 4x4 not working jjones12 ATV Repair and Maintenance 11 12-09-2010 02:15 PM
