Draining and replacing coolant - Polaris ATV Forum
Old 05-04-2011, 07:59 AM
johny84's Avatar
Member #14727
Hello all,
Can someone plesase describe exactly how to replace coolant in a 2005 sportsman 700 efi ?
Thank you!
Old 05-04-2011, 02:00 PM
Old 05-15-2011, 03:24 AM
johny84's Avatar
Member #14727
Drain plug location (sportsman 2005)
can someone please help and tell me where is the radiator drain plug on a sportsman 700 efi (2005) ?
Thank you!
Old 05-15-2011, 05:11 AM
Member #1958
The drain is on the lower right hand side of the radiator.
Old 05-15-2011, 06:34 PM
sman700's Avatar
Member #12597
It's easy, just drain the old stuff, flush it out if you want, then fill it back up with about a 50/50 to 60/40 mix. Let it run with the cap off making sure to rev it up every so often. This will help the coolant flow through the system and get any air out of it. When you feel all of the air is out of the system, put the cap back on and make sure your overflow reservoir is filled to the proper level. Double check the levels before and after your next ride.
Are you changing the coolant just as a maintenance issue or are you having overheating problems?
If you are having overheating problems, check to make sure your radiator is clean and no mud/dirt is built up in between the fins.
Old 05-16-2011, 04:14 AM
johny84's Avatar
Member #14727
Thank you !
Going now to try and find that drain plug...
2005 polaris sportsman 500 where to fill coolant
antifreez change polarus 700
antifreeze 2005 polaris 700 efi
changing coolant in polaris 500
coolant for polaris sportsman 700
how to change antifreeze on a sportsman 700
how to change sportsman coolant
how to drain antifreeze out of a 2001 sportsman 500
how to fill the coolant on 2002 polaris 700
polaris engine oil weight
polaris sportsman coolant change
when to change coolant in polaris atv
Draining Mikuni BST40 Carb pjmartin ATV Repair and Maintenance 3 03-31-2011 01:01 PM
Allied Electricals: Coolant Pump | Industrial coolant Pump in India Bangalore Allied Site Issues & Suggestions 1 11-19-2010 02:13 PM
Something Draining Battery??? Quantum673 Polaris Sportsman 7 10-14-2010 04:34 PM
Replacing A-Arm Indypo Polaris Sportsman 4 10-01-2010 07:39 PM
draining radiator on 06 sportsman 500 efi sligster ATV Repair and Maintenance 1 08-30-2009 10:36 AM
