Front drive shaft removal - Polaris ATV Forum
post #1 of 6 (permalink) Old 05-08-2011, 11:01 AM Thread Starter
jleo1's Avatar
I can't figure out what I'm doing. I have 2 Polaris quads. a 330 Magnum and a 55 ATP. Both are 2004. Both have bad cv joints and need to be replaced. The 500 is destroyed and needs the whole shaft replaced so I bought 2 whole shafts. I can not get them out of the front differentials to save my butt!
There is a circlip on the end of the shafts that keeps them in the differential. How on earth do you get them out? I've searched youtube and can only find people taking apart other quads, not Polaris. Those just seem to pop right out by hand. Mine will not! I've tried prying them out, yanking them out and all kinds of mess. My neighbor is a big guy and he can't get them out. HELP ME PLEASE, SOMEONE!!!!!
jleo1 is offline
post #2 of 6 (permalink) Old 05-08-2011, 12:17 PM
rez_ford's Avatar
Get 2 pry bars or screwdrivers, and put them on the opposite side of each other and pry at the same time. It should pop right out, that's how I did it,
rez_ford is offline
post #3 of 6 (permalink) Old 05-08-2011, 02:39 PM
Bruce! is offline
post #4 of 6 (permalink) Old 05-08-2011, 06:20 PM
racer37l's Avatar
Most of the time you have to soak them with penetrating oil for a while, then try the pry bars. Sometimes they can be stubborn!!
Con
racer37l is offline
post #5 of 6 (permalink) Old 05-09-2011, 06:57 AM Thread Starter
jleo1's Avatar
Thumbs up Thanks
Thanks guys,
My son and I got them all out. While waiting for a reply we went out and took the whole front differential out with both shafts still in place. We then disassembled the whole thing to see how it was built.
We found that the shaft never actually enters the differential so I sprayed WD-40 all down around the shaft at the differential (basically filled the hole up) and let it sit awhile.
In the meantime I ran to my brother's and borrowed his ball joint fork. It barely fit but it was good enough. Tryed it on the one without WD-40 and it didn't want to budge. Tryed the one with WD-40 and pop... right out it came! Sprayed the other one and waited a couple seconds and it came right out too.
Until I learned, by taking it apart, that I would only be prying against the cup which held the shaft I was afraid of tearing something up by hitting it to hard. The WD-40 is what made it all happen though.
Thanks for the info everyone! I appreciate it. Now we both know how they are built too and I especially like the part that my 15 YR old son is learning something besides Xbox and texting and just tearing up the quads and cycles and then leaving them for me to fix! And he seems interested. Thanks again, Jeff
jleo1 is offline
post #6 of 6 (permalink) Old 05-09-2011, 06:36 PM
racer37l's Avatar
Way to go!
Glad to see you're making the repair a family project!!
It's always good to see things like this from two perspectives!
Good luck!!
Con
racer37l is offline
rear drive shaft removal 304ronnie ATV Repair and Maintenance 8 08-26-2011 11:18 AM
Front Drive Shaft Removal maverick11 ATV Repair and Maintenance 1 04-21-2011 09:59 AM
2002 Sportsman 700 rear drive shaft removal pbm1957 ATV Repair and Maintenance 5 01-20-2011 08:49 AM
Front Prop shaft removal rifleman24 ATV Repair and Maintenance 0 11-08-2010 06:26 AM
HELP, rear drive shaft removal. rust Polaris Sportsman 2 08-16-2009 03:58 PM
