Old 05-08-2011, 09:09 PM
kellum410's Avatar
Member #2111
Question 05 EFI 700 Sportsman Just Shuts Down Electrical
My 05 700 Efi Sportsman has been doing fine today I went riding had low beam lights on and was returning home and it just shut off everything , display blank, no fuel pump nothing, sat there maybe 10 seconds switched back on started back up everything alright, did it twice more, acted same way, turned lights off it ran back home that time, I am thinking pdm or ecu what ever you call it what do you guys think? Acts just like a circuit breaker getting hot.
Old 11-13-2011, 02:33 PM
RickCuddihey's Avatar
Member #20414
I have the same problem, any luck finding the issue?
Hi.
I have a 2004 Polaris 700 that just started to do the same you describe. It shuts off when ever the headlights are on but starts again if I wait.
I did all the trouble shooting on the electrical system discribed in the repair manual and the system is good. Charging, etc. is 'A' OK. Kinda stumped by this.
Did you ever find the problem?
Cheers,
Rick
Old 11-14-2011, 05:36 AM
kellum410's Avatar
Member #2111
It has been a while but I will try I think that there were some circuit breakers say four of them , open front cargo cover pull radiator cap cover right in the area behind radiator cap but in front of steering stem four breakers in a row I just went ahead and changed all four, instead of buying the OE Polaris ones I went to parts store and bought a universal type spade circuit breaker you just cut the spades to the length you need, cheaper but it is your choice, best I can remember that did it, best of luck
Old 11-14-2011, 11:15 AM
AKStew's Avatar
Member #5212
I bought my self-resetting circuit breakers from the the link in this thread:
Cheap Place to Get Self-Resetting Circuit Breakers
2011 Sportsman 500 HO Touring: Polaris 3500 lb. Winch, Kimpex Adventure XL Trunk, 7" Passenger Foot Risers, UNI Foam Filter
2006 Sportsman 500 X2 EFI: Superwinch Terra 25 w/Synthetic Rope, Kolpin 4 gal Gas Pack, 3" Passenger Foot Risers, 3-Headlight Mod, K&N Filter
SOLD 2010 Sportsman 300: Polaris 2500 lb. Winch, Kolpin Rear Seat (for the dog), UNI Foam Filter
SOLD 2006 Sportsman 700 Twin EFI: 27" Mud-Lite XTR, Superwinch Terra 35 w/Synthetic Rope, Polaris HD Front Springs, OEM Front Bumper Guard, WES Rear Seat, Kimpex Fender Guards w/Footpegs, 3-Headlight Mod, K&N Filter, Symtec Heated Grips
Old 11-14-2011, 02:05 PM
mstermechanic907's Avatar
Member #17047
Send a message via MSN to mstermechanic907
ive had this problem on a few machines in my shop,it kept tripping the circuit breaker.there was a short in the electrical system,the cooling fan motor was fried.it melted the power wires going to the fan,we unpluged the fan at the connector and the breaker quit tripping.we repaired the melted wires and changed the fan motor,everything was good after that.
Tags
700, display, ecu, electrical, pdm
05 polaris spirtsman 700 electrical
2003 polaris sportsman 700 shutting off when hot
2004 polaris 700 getting hot an shutting down
2004 polaris sportsman 700 ecu
2004 polaris sportsman 700 shuts down with headlights
2006 polaris sportsman pdm 3 blade connector direction
circuit breaker polaris 700 amp
elctrical short awd 700 sportsman atv
how to reset ecu polaris sportsman
my polaris sportsman 700 shuts down after 20 minutes
polaris 2005 sportsman 700 forum electrical short
polaris headlights shut off
polaris lights shuting off problem
polaris sportsman 700 ecu problems
polaris sportsman 700 electrical
1996 Sportsman 90 shuts down bmacom ATV Repair and Maintenance 10 09-08-2012 05:54 AM
Gets wet and shuts down!!! n2mudn ATV Repair and Maintenance 4 02-20-2011 11:18 AM
2004 Sportsman 400 shuts down after 15min jdlane3613 ATV Repair and Maintenance 0 06-03-2010 06:25 AM
08 Sportsman 400 HO shuts down. astro57 ATV Repair and Maintenance 6 07-01-2009 01:11 PM
2004 Sportsman 600 shuts off randomly trose ATV New Members 0 04-27-2009 04:26 PM
