10-21-2009, 07:05 AM
Member #1752
Sportman 500 ... Hard shift???
Guys,
I have an 2007 EFI Sportman 500. Doesn't have many hours and has not been used harshly at all.
Has been a very wet summer and fall. Kinda like living in a rain forest. Bike has spent much time in the rain as a result.
Has been getting progressively more difficult to move the shift lever. Seems to move fine when it is in gear.
Is there a place to lube the shift mechanism from the outside? Is this a known problem? Is it an indicator of a severe problem?
Thanks!
Mike
10-21-2009, 08:17 AM
10-21-2009, 10:12 AM
Member #618
If you look at the shifter,there is a shift link rod that connects to the shifter (under side).The shift rod has a tie rod end looking fitting on the trans end of it.You can put WD40 or grease on it.It looks like you live about 10-15 minutes from me.
06 Predator 500 TLD
07 Sportsman 500 EFI
09 Sportsman 550 XP
10-21-2009, 10:17 AM
Member #1752
Slider,
Will get the can of WD-40 and go lookin'. Am in Elkview ... near Frame.
Mike
Just hit the linkage with some Break-Free (which is a teflon bearing light lubricating oil)! Boy does THAT make a difference!!!
Thank you :-)
Mike
10-21-2009, 10:18 AM
Member #618
Cool.I will be in Elkview this evening putting a lift kit on a RZR.
06 Predator 500 TLD
09 Sportsman 550 XP
10-21-2009, 10:21 AM
Member #618
Do you ride at Sanderson or Quick?
06 Predator 500 TLD
09 Sportsman 550 XP
10-21-2009, 10:27 AM
Member #1752
I just use the bike as a tool around my small farm and hunting up the hill.
Not very exciting but very, very useful!
Thanks again!
10-21-2009, 10:32 AM
Member #618
No problem.If you want to ride sometime,let me know.Most of the guys I ride with live in Elkview and Clendenin.
06 Predator 500 TLD
09 Sportsman 550 XP
08 sportsman touring hard to put in gear, 1996 sportsman 500 shifting hard when running, 1999 polaris sportsman 500 hard to shift and grinding into gear, 2004 polaris sportsman 500 difficult to move shifter, 2004 polaris sportsman 500 ho, hard to shift, 2004 polaris sportsman 500 shifter grease, 2004 sportsman shifting problem, 2007 polaris sportsman 500 hard to shift, 2007 polaris sportsman hard to put in gear when running, 2008 polaris sportsman 500 hard to shift, how to replace the shifter shaft in predator 500, polaris 500 hard to shift, polaris atv 500 ho 2001 hard to shift, polaris atv 500 sportsman stiff shifting, polaris sportsman 500 hard shift handles, polaris sportsman 500 hard to shift, sportsman 500 atv hard to shift, sportsman 500 hard to shift, sportsman 500 very hard to get into gear, what oil do i use in shifter on sportsman 500
