gas leak - Polaris ATV Forum
Old 05-13-2011, 05:58 AM
raywag's Avatar
Member #15006
gas leak
i have a 250 trail blazer with a gas leak i checked the hoses and tank can not find leak dealer said need new something in carb as gas is leaking out of a hose. im 64 and need some help thanks ray
Old 05-13-2011, 06:24 AM
cwlongshot's Avatar
Welcome,
First you gotta fine from where it's leaking. Isit the carb or a hose or the filter or the pump ....
Time to get your knees dirty!! Let us know what you find!
If it's outta the carb could bs the float is stuck. That's a rebuild needed. Not terribly difficult. Kits are available based of make and model.
2015 RZR 900 Trail BLK. Pearl
Lock N Ride roof
Lock N Ride 1/2 windshield
Lock N Ride rear box
LED lights front, top & rear
LOTS more coming...
Old 05-13-2011, 06:52 AM
I thought you needed help because your 64?? Oh and welcome to the board!
Old 05-13-2011, 01:38 PM
big4x4mudder's Avatar
Member #4725
I had a leak from the fuel shut off valve I had replaced the gasket 2 times before I found it was leaking from the valve and if I pulled out on the knob as I turned the valve it would stop leaking, so you may want to check the fuel shut off valve out.
Ride it like you stole it!
94 sportsman 400 SOLD
01 sportsman 400
?? 110 Quadzilla
2007 polaris atv leaks gasoline
atv gas leak
atv gas tank leak
gas leaking from fuel filter atv
polaris 250 gas value
polaris atv fuel leak
polaris atv gas leak
polaris atv gas shutoff
polaris big boss fuel shutoof valve leaking
polaris gas leak
polaris sportsman gas tank valve leakage
repairing gas tank leak polaris ranger
oil leak sliderus ATV Repair and Maintenance 1 10-02-2010 06:02 AM
gas leak shawnboy87 ATV Repair and Maintenance 8 09-16-2010 03:15 PM
02 500 oil leak Sampson Polaris Sportsman 1 06-28-2010 06:07 AM
Help! Oil leak 02 700 dtsesthx Polaris Sportsman 2 04-22-2010 01:10 AM
Bad Oil Leak Ozquad Polaris Sportsman 0 01-15-2010 09:23 PM
