02 Sportsman 500 H.O. Won't Shut Off - Polaris ATV Forum
Old 05-21-2011, 08:48 AM
gmiller0737's Avatar
Member #1628
I recently purchased a nice used Sportsman 500 H.O. most times the engine will not shut off by turning the key off sometimes it will run for a minute or longer with the key off,Turns off normally with the switch on the handle bar what could cause this or is it made that way?
Old 05-21-2011, 10:28 AM
ebaysnyper's Avatar
Member #13772
Send a message via Yahoo to ebaysnyper
Sounds like a bad ground. Fallo the wires from the key inside the pod and keep an eye out for a groung not connnected. If you can't find one then replace the key switch
Sent from my Droid using Tapatalk
2007 sportsman 500 x2 efi
26" sadona ripsaws on 12" itp ss312's
3 headlight mod relay type
2500 Ib polaris winch
custom made "winch saver"
custom work light mod with lighted switch and 18 Watt lamps
custom stealth black shock covers
Front trunk locks Polaris Part #2874548 $7.50 each @ dealer
front rack rails converted to "U channel" strut for easy attachments
pure polaris HD front springs
Old 05-26-2011, 03:43 AM
Member #1628
It's fixed the problem was the ignition switch.
Old 05-26-2011, 04:15 AM
pjmartin's Avatar
Member #5074
Send a message via ICQ to pjmartin
Good thread. I now realize I have a problem I didn't know I had. The ignition switch on my 2001 500HO seems to control only the speedometer and indicator lights. The quad will start and stop with the kill/starter switch with the ignition switch in either on or off position. Thought it strange but the quad is new to me. Turning off the ignition switch doesn't kill the engine. Doesn't keep me from using the quad but I'll check it out next time I get the chance. Did you have to replace the ignition switch or was it just a bad connection. Would appreciate details of your fix.
Old 05-26-2011, 04:58 AM
Member #1628
On mine if you turn the key off slowly just before it got to the off position it would shut off normally but if you just turned it from run to off it would stay running unless it was turned off using the switch on the left handle bar,Got the new switch off eBay for around $50 shipped be cautious when shopping as there are used switches on there too for about the same $ I got a new one.
Old 05-26-2011, 05:08 AM
pjmartin's Avatar
Member #5074
So your problem was the switch itself being bad.
I'll start my troubleshooting with the wiring and if I end up needing a new switch so be it.
Old 05-26-2011, 08:01 AM
pjmartin's Avatar
Member #5074
Just tested mine
-key off quad won't start
-key on all ok
-Quad running, turn key off quickly, no effect on engine but speedo turns off.
-Quad running, turn key slowly to off and engine stops when key hits about 80% of its travel, speedo turns off at same point
Looks like exactly the same problem. Not sure if it's worth fixing unless it can lead to complete switch failure down the road. It's like the switch travels too far and makes ignition contact again before the engine has stopped when the key's turned quickly. Turn the key slowly and everything's fine.
Old 08-28-2012, 06:12 PM
BadjerJim's Avatar
Member #29465
Thanks all for the info. This is exactly the problem I'm having. Odd: when the engine keeps running (key OFF), the kill switch won't stop the engine either. Quad is a yr 2002 Sportsman 500 HO.
2001 polaris sportsman on/off switch won't turn off engine
2001 polaris sportsman wont cut off with key
polaris 2002 700 sportsman will not turn off with switch
polaris sportsman 500 will not turn off
polaris sportsman 500 wont shut off
polaris sportsman 500 wont turn off
polaris won't shut off
polaris wont turn off with key switch
sportsman 500 ignition turn off
sportsman 500 key wont turn off
will not shut off 2002 polaris sportsman 500
Can I shut off the On-demand AWD on a 2009 Sportsman 500? buster634 Polaris Sportsman 20 06-17-2010 03:16 PM
94 sportsman boggs mid throttle/will not shut off ratherbflyn Polaris Sportsman 2 05-05-2010 09:11 AM
1995 sportsman 300 4x4 nd gas shut off s/w rickhise ATV Repair and Maintenance 3 02-28-2010 12:19 PM
07 Sportsman 500EFI Hot Gas Shut Down?? sporthog ATV Repair and Maintenance 1 09-01-2009 01:40 PM
08 Sportsman starter stick/shut down Garrett32 ATV Repair and Maintenance 1 06-15-2009 10:15 AM
