  #41 (permalink)
Old 04-18-2012, 08:21 PM
KICKER431's Avatar
Member #18006
Thanks for posting all this Mikedirenzo. I have a feeling a lot of people can use this thread. I will keep it bookmarked for when I need to do any clutch / belt work.
MINE:2004.5 Sportsman 700 EFI Mossy Oak (motor changed after drowning)
BigWes cargo box, WES Universal Passenger Foot Pegs, UNI air filter, Symtec Heated grips
Warn 2500, Thermotec exhaust wrap, Reverse Override, 3 Headlight Mod
RotoPax 2+2 gallon Fuel Packs, EPI HD Springs (all 4 corners)
Coleman soft cargo bag, WES Universal Passenger Foot Pegs, UNI air filter, Symtec heated grips
Warn 2500, ThermoTec exhaust wrap, Reverse Override, 3 Headlight Mod
  #42 (permalink)
Old 04-19-2012, 09:13 AM
mikedirenzo's Avatar
Member #7016
Glad to do it. I am going to be posting an article on my new KFI 2500 winch install.
2010 Sportsman 500 HO
KFI 2500 Winch
Richochet Under Armor (Full Packagage)
Rotopax 4 gallon with Universal mounting plate
Trails
  • Hatfiled Mcoy 2011
  • Brown Mountain Beach ORV 2012
  • Carolina Adventure World 2010, 2011, 2012
  • Brimestone ATV 2012
  #43 (permalink)
Old 05-16-2012, 09:26 PM
apaka's Avatar
Member #24283
I had a similar problem on my 2006 magnum 330. I blew out my belt...
But when I went to put the new belt on, it seemed overly loose and it hit the cover as well. So I found this thread and after rigging myself up a nice spring compressor to get the c-clip off the back of the secondary I found a huge amount of belt dust and abnormal wear on these so called "buttons" and a bit of wear on the helix riders as well. I ordered new buttons and a new spring, just because I'm here, after its all back together ill fine tune the belt tension via the washers behind the secondary, I have 4 back there currently so I have some room for adjustment. Here's a pic of one of the buttons
Ill let you know how it all goes when I get it all back together!
Thanks for all the tips and insight, always appreciated.
03 polaris 700 belt instal
2007 sportsman 500 efi belt slapping case
clutch atv produce
how much do it cost to install a clutch belt on a 500 polaris
how to change belt on 05 sportsmen 500
how to change polaris sportsman drive belt
how to install a belt on polaris 330 magnum
how to install belt on atv
how to install belt on polaris sportsman
how to install belt on sportsman
how to know if a bearing has went bad on a polaris fourwheeler drive belt
polaris belts instillation
proper way to install belt polaris sportsman
repacing the belt drive on a polaris 4-wheeler
what is the reason for a drive belt in a four wheeler polaris
good belt bad belt or all the same? notdaddys ATV Repair and Maintenance 30 06-30-2011 11:00 AM
My HID install '11 SP antoniodef Polaris Sportsman 20 05-05-2011 12:39 PM
jet kit writeup/install help. 425whpsti ATV Performance Modifications 1 04-15-2011 02:12 PM
any buy and install this HID kit???? hotairgypsy ATV General Discussion 20 03-04-2011 10:53 PM
A Arm install....Help? Bobby002 ATV Performance Modifications 3 02-03-2011 02:21 PM
