1999 250 2-STROKE TRAIL BOSS
I have owned this Quad since new, always rock solid.
But i cannot get it to start at all. Have worked on every 2 stoke out there,bikes,boats, quads,weed eaters etc. Pretty simple stuff, got good gas,got
spark, got air, got compression, it should go! I will try to summarize the situation
quickly, labor day 2010 was the last time this bike ran perfectly. I let it sit in my
shed at the lake house until Nov. 6 2010 when i tried to start then, just cranks
no start. It's got spark, even changed the plug. Took it home, thought it had bad gas, cleaned out the carb and drained all the gas out. Recently i put fresh gas in ,no start, just cranks, no life no fire.
I have been through checking 3-4 times:
NEW PLUGS - 3
DISASSEMBLE CARB, clean all jets, passages, needle and seat, float level, choke circuit adj. throttle cable adj. vent tubes,everything multiple times
HAS SPARK, COMPRESSION, INTAKE BOOT GOOD, SUCKS AIR IN FROM INTAKE
The last idea is E.T.C. problem possibly? Any ideas please!
NEW PLUGS - 3
