250 trail blazer oil change - Polaris ATV Forum
Old 10-31-2009, 06:51 PM
metal man's Avatar
Member #1839
I recently purchased a 2001 Polaris 250 trailer blazer. I want to change the transmission oil, located the dip stick, however I can't locate the drain plug. Also, can I use a standard two stroke synthetic 10- 40 gear oil such as Motul type PE. Is there a link out there that shows part diagrams? Thanks for your help
Old 10-31-2009, 10:16 PM
Old 11-01-2009, 06:06 AM
metal man's Avatar
Member #1839
Thank you,
I enjoy this site very much,especially when I no nothing about Polaris
Old 11-02-2009, 05:52 PM
kankawi's Avatar
Member #1856
you should use polaris agl fluid only any thin else causes premature chain stretch (internal chain)
Old 11-03-2009, 07:49 PM
metal man's Avatar
Member #1839
Thanks for you help, I'll will be sure to use this oil
Old 07-21-2011, 03:40 PM
dyoung's Avatar
Member #16902
Help!!! i need the answer to this!!! tho i feel silly saying i cant find the drain plug.
Old 10-15-2011, 01:29 PM
darktacos's Avatar
Member #19566
hi
ok the drain plus on same side as the rear brakes below trans ull see a bolt with a stop nut on it u have to scew in bolt all the way before u can back out plug it a safty bolt so it will not come off
it funny becuz it took me somt time to find it also lol and why was the bolt up against the frame
hope this helps
Old 01-30-2012, 09:32 AM
Medevack1's Avatar
Member #21682
http://www.cheapcycleparts.com/model...emblies/101753
03 paladin trailblazer 250 oil change
2001 polaris trailblazer 250 oil change
2002 polaris trailblazer 250 oil change
change polaris trailblazer motor oil
how do u change gear oil on polaris trailbalzer 250
how to change oil in polaris 250
how to change oil on polaris trailblazer
how to change oil on polaris trailblazer 250
polaris 250 trailblazer oil change
polaris trailblazer 250 transmission oil
polaris trailblazer oil change
