07-04-2011, 01:51 PM
Member #16511
2005 Ranger 500 4x4 won't start
In need of some help, please! It just will not start. I've changed the battery, ignition coil, CDI, spark plug, checked the stator and it checked out good. I also checked the starter and it seems to be good. When I changed the spark plug it was wet and you could smell gas on it. I know it gets a spark because I can see the spark when i do the spark check. It turns over all day long but will not start. Does it have a kill switch? Does it have an ECU or fuse box because I haven't seen one yet? Does anyone have a manual for it?
07-04-2011, 02:05 PM
Member #14871
if you have spark and fuel it should start, but if you have low or no compression it won't ever start try doing a compression check. that's wit i'am talking about
07-05-2011, 12:35 PM
Member #16511
Now I'm not getting any spark. What can cause this problem?
07-05-2011, 01:23 PM
Member #858
Check all your fuses and breakers....Stator, PDM...power dist module....
2009 Polaris 500 HO
Front&Rear Brush Guards
2500lb Polaris Winch
2" Ez install lift kit
Front &Rear Extenders
Polaris hand guards
K&N airfilter box system
My FenderGuards
EPI Clutch System. 2010 camo
SunPro Temp gauge. 550xp Sportsman
Xbow Gripper mount
~DOWN&DIRTY~
07-06-2011, 07:15 AM
Member #16511
I finally have a spark but now it doesn't seem to get fuel. It seems the fuel pump pumps fuel into the carb and then stops after about 5-10 seconds. Is this normal? What causes the carb not to pass fuel into the engine? If I spray it with some lighter fluid (I know your not suppose to) it wants to crank but as soon as it burns up the lighter fluid it stops wanting to crank. Please Help, anyone!
07-06-2011, 01:43 PM
Member #12678
New fuel filter??
2007 Sportsman 800
1300 miles, mostly at Hatfield-McCoy trails, WVa.
07-08-2011, 12:37 AM
Member #16511
I received this polaris in bad shape. At first the carburetor was flooding, so I cleaned it out, so then it was not flooding anymore. The key switch was missing so I found the right wires to make it work(orange and white/red and red/white). I was not getting a spark and then now I get one. This whole time I've been messing around with this the engine turns but doesn't crank(main problem). If I spray some carb cleaner it wants to crank until it burns off the carb cleaner. I've swapped out the whole ignition system(spark plug, ignition coil, spark plug, starter selonoid), cdi, pdm/ecu, and carburetor with another polaris that is running and still no luck. I did check the stator and it has the correct ohms. I don't have the capabilities to do a compression test. I mean there is nothing else that I can change but the engine? Please help with any advice or recommendation.
07-08-2011, 02:17 AM
Member #4649
Might be a timing issue. The ignition pickup on the flywheel has been known to rotate, causing the ignition timing to be way off.
Valves could be out of adjustment, causing a lack of compression.
If you just cleaned out the carb, but didn't replace the needle and seat, that could be the problem. You may have cleaned out debris that was keeping the needle from sealing off, but now it may be stuck in there preventing fuel from flowing.
Check the carburetor boot (going from the carb to the cylinder) for cracks or tears. That will completely screw up the fuel mixture.
Just some ideas.
2006 Sportsman 450
HD springs
Front Brushguard
3 headlight mod
55w driving lights
07-09-2011, 01:38 AM
Member #16511
Hey Razorback thanks for the ideas. I checked the alignment of the timing between the flywheel and the spocket on the head, and it was off. So I realign the timing and made sure the carburetor was clean. I still get a spark and the timing sounds alot better but still a no go on the start up. I sprayed some carb cleaner into the carburetor and it actually cranked over for a few seconds. It seems to me like it's not getting any fuel but I can feel the pump going and then it stops. Any more ideas?
07-09-2011, 02:04 AM
Member #4649
The fuel pump works off of vacuum pressure from the engine. If it's not rotating/running, then the pump isn't going to work. I bet you have a stuck needle valve. They are one of the most common problems in polaris carbs. They don't cost too much. If this machine was in the shape you described, then it would be a good idea to replace it anyway. It was probably what was causing the flooding in the first place.
2006 Sportsman 450
HD springs
Front Brushguard
3 headlight mod
55w driving lights
2004 polaris ranger out of gas prime pump, 2004 polaris ranger starting problems, 2005 polaris ranger 500 cdi issue, 2005 polaris ranger 500 sometimes has a spark, 2005 polaris ranger fuel pump problems, 2005 polaris ranger won't start, 2005 polaris ranger won't start just clicks under battery, 2005 polaris ranger wont start, 2005 polaris ranger, flood, 2005 ranger 500, 2006 polaris ranger will not start, polaris ranger 500 started then wont, polaris ranger 500 wont start, polaris ranger won't start, polaris ranger wont start
