Old 11-09-2009, 03:50 PM
fmongeau's Avatar
Member #1842
Torque Specs for 2004 Sportsman
Does any one know where to find the torque specs for a 2004 Polaris Sportsman? I am getting ready to rebuild the front end on the machine and would like to know if there is any specs on the torque for the hardware.
Old 11-09-2009, 06:02 PM
4play's Avatar
Member #1644
110ftlbs for the centre axle nut, the rest tight with locktight.
Old 11-14-2009, 07:44 AM
fmongeau's Avatar
Member #1842
Thank you again. I am getting ready to go out and start putting the machine back together.
Old 04-05-2010, 08:09 PM
overdbars's Avatar
Member #4106
?? Torque Spec's ??
I'm questioning the 110 foot lbs for the axle nut. I don't think we are on the same page here. I just replaced front rotors & pads on a 2001 500 Sportsman. I used 16 foot lbs anything tighter the wheel will not rotate freely. I don't think this (16lbs) is correct & I'm still researching this spec. I saw the 110 lbs so I went to 30 foot lbs & was unable to turn the wheel at all. If anyone knows the spec on the front axle nut for a 2001 please post it. 110 is very questionable.
JD
Old 04-06-2010, 03:52 AM
cowslinger64's Avatar
Member #3793
below is out of the manual for the 02 Sportsman 500. I'd imagine its the same. If you're gonna do this sort of work, I'd recommend getting a manual for it.
1. Torque spindle nut to 160-170 inch lbs. (18--19
Nm) while rotating hub continuously.
2. Back off nut 1/2 turn.
3. Rotate axle several revolutions by raising rear of
machine and rotating rear wheels with the
machine in gear.
4. Re-torque hub nut to 108-144 in. lbs. (12--16.3
Nm).
5. Install cotter pin. Bend each leg of cotter pin
around castle nut in different directions. See
below.
NOTE: If cotter pin hole does not align, tighten slightly
to align and install pin. Do not exceed 144 in. lbs. (16.3
Nm).
6. Reinstall hub cap.
7. Remove fill check plug and rotate hole to either
4:00 or 8:00 position.
8. Fill with Polaris Premium Demand Drive Hub Fluid
or Type F Automatic Transmission Fluid until fluid
trickles out. NOTE: Do not force the oil into the
hub under pressure. This can cause seal damage
and leaks.
9. Reinstall plug.
10. Reinstall brake caliper assembly. Torque retaining
bolts to 18 ft. lbs. (25 Nm).
11. Reinstall front wheels. Torque retaining nuts to 15
ft. lbs. (21 Nm).
12. Carefully lower vehicle.
13. Field test vehicle for proper operation of brake
system and AWD operation.
Old 04-12-2010, 08:16 AM
overdbars's Avatar
Member #4106
Thanks,
I did take the 110 ft lbs & then divided them by 12 to get the inch pounds.
(that put me in the ballpark). Thanks for the update & the added instructions.
JD
04 polaris sportsman 500 ho head bolt torque specs
04 polaris sportsman 600 axle nut torque
04 sportsman 500 ho front axle nut torque
04 sportsman 700 axle nut torque
2001 polaris 400 sportsman head bolt torque specs
2001 polaris sportsman 400 torque hub
2004 polaris 600 torque specs
2004 polaris sportsman 600 hub nut torque
2006 polaris hawkeye cv shaft nut torque spec
500 ho rocker arm torque
font axle nut torque spec polaris 04 400 sportman
head bolt torque specs for 2004 700 polaris atv
how many ft lbs to tighten polaris sportsman hub nut
polaris 2003 sportsman front hub torque
polaris 700 efi rocker arm torque
polaris auto transmission torque specs
torque specs for 500ho polaris atv
what is the foot lbs torque for rear axles polaris 2012 400 ho
what is the torque spec. on the rear axle nut 2004 sportsman 500
whats the torque spec on polaris sportsman 500 ho head bolts 2001
