Old 07-13-2011, 03:10 PM
ajmicek's Avatar
Member #11636
Polaris xplorer 250 Electrical issues
so the other day the battery in my polaris xplorer died, and wouldnt hold a charge, so i bought a new one. well the new one works just fine...except when some relay malfunctions and i lose power on 4x4, starter and headlight/taillight. i hear a "click" noise soon after i turn the key, then it pulsates (i know this because i turn the headlight on and it flashes off and on every 10 or so seconds) and the starter doesnt work after the relay trips. i need to know how to fix the relay, and dont know why its doing this.
Old 07-13-2011, 03:24 PM
2g00d4u's Avatar
Member #15334
did you get the right battery for the quad? is the right amount of voltage getting into the battery? is the stator producing enough charge?
1998 Polaris Magnum 425
Kenda Bear Claw Tires - 3000lb winch
Old 07-13-2011, 05:46 PM
ajmicek's Avatar
Member #11636
the thing starts fine sometimes, other times i have to pull start it. and i cant keep it running too long because the cooling fan doesnt work because of this electrical issue. my buddy has a voltage tester and he's coming over later this week and im gonna test it then. do you think that the battery could have been overcharged?
Old 07-30-2011, 06:08 AM
abbie50's Avatar
Member #17204
I have the same problem. Started with starting sometimes and ended with not starting at all. Have the wiring diagram but cannot find the common point where the red/white splits and goes to. Does start with the pull cord, but no fan or 4 WD.
Old 08-03-2011, 08:08 PM
ajmicek's Avatar
Member #11636
I still haven't figured it out but I'm going to silver lake sand dunes tomorrow and my 4x4 still wont work! And the battery died. Any suggestions as to what I should do to try and get this thing working again? None of the lights for neutral or reverse work, nor the headlights ( although the headlights worked fine the other day when I went riding at night).
2000 polaris explorer 250 4x4 cooling fan
2000 polaris explorer not charging
2000 polaris xplorer 250 electrical running without battery
2000 polaris xplorer 250 running without battery
2000 polaris xplorer 250 wiring diagram
2001 polaris 250 atv electrical
2001 polaris xplorer 250 clicking noise when key is on no neutral light
2001 polaris xplorer 250 wiring diagram
cooling fan for 2000 polaris 250
headlights on my polaris xplorer wont work
model number for battery for 2001 polaris xplorer 250
my polaris explorer wont charge battery
polaris xplorer 250 forum
polaris xplorer headlight malfuction
starter located on a 2000 polaris xplorer 250 4x4
polaris xplorer vin # issues lit18265 ATV New Members 4 03-13-2011 08:12 PM
1999 polaris xplorer 400 electrical issues?? wisemind2 ATV Repair and Maintenance 3 01-04-2011 09:58 AM
xplorer electrical problems dieseldan2005 ATV Repair and Maintenance 7 12-18-2010 07:27 AM
99 polaris xplorer 400 issues need help please wisemind2 ATV Repair and Maintenance 7 09-18-2010 08:50 AM
Starter issues on 2001 polaris xplorer 4x4 Diveking ATV New Members 1 09-23-2009 12:33 PM
