  #11 (permalink)
Old 12-11-2011, 01:50 AM
gilgil's Avatar
Member #19750
Send a message via Skype™ to gilgil
Hi
when driving my scrambler 500 2003 in outside temp of 20-25 degrees celcius my fan comes into action from time to time.is it normal? should the radiator cooling system be enough? is it normal?
thanks for any input
Gil
cooling fan sensor location
heatt sensors for atv
how do you jump the temp switch,so the fans will come on?
how to check temp sensor polaris sportsman
how to test heat sencer on polaris atv
how to test temperature switch on polaris 400
polaris 400 fan switch
polaris atv cooling switch
polaris atv fan relay
polaris atv fan switch troubleshooting
polaris fan relay
polaris scrambler temp sensor test
polaris sportsman 800 temp sensor
polaris sportsman 800 temp sensors
polaris sportsman cooling fan switch
polaris sportsman engine temperature sensor
polaris sportsman fan sensor
polaris temp sensor
repairing a thermo fan switch
thermal switch for polaris 500
Need help on a 90 trailboss 250 temp sensor gsbeers ATV Repair and Maintenance 4 07-26-2011 05:45 PM
MAP sensor problem Manny ATV Repair and Maintenance 0 06-21-2011 07:07 PM
cooling system problem atvman2010 ATV Repair and Maintenance 16 01-31-2011 05:40 PM
sportsman 500 ho temp.sensor 4getful2 ATV Repair and Maintenance 3 10-25-2010 05:34 PM
Air Temp Sensor?? Opex Polaris Sportsman 5 06-24-2009 01:05 PM
