Old 07-16-2011, 12:02 PM
MUDDIE49's Avatar
Member #858
Cooling fan intermitting problem...Temp Sensor?
Ok....replaced a thermo fan switch in may 2011...Fan ran fine since now..would'nt run the other night...jumped the connector fan went on...connected it fan would'nt run....unhooked the temp sensor and fan still would'nt come on....and never got a HOTT light...My Question is this...it's a single wire temp sensor the fan should have gone on.? and it this maybe why my Hott light is not comming on...and i'm having a intermitting fan problem...?
2009 Polaris 500 HO
Front&Rear Brush Guards
2500lb Polaris Winch
2" Ez install lift kit
Front &Rear Extenders
Polaris hand guards
K&N airfilter box system
My FenderGuards
EPI Clutch System
SunPro Temp gauge
Xbow Gripper mount
~DOWN&DIRTY~
Old 07-16-2011, 01:45 PM
MUDDIE49's Avatar
Member #858
Well ran it tonight.....210 degrees no HOTT light or cooling fan operation...i had to jump the thermo fan switch to cool it down....anybody??? I'm thinking Temp sensor....no light and no operation, what confuses me is the fan does'nt work if you unhook the temp sensor....hmmm...what a battle this has been!!!
2009 Polaris 500 HO
Polaris hand guards
My FenderGuards
EPI Clutch System
SunPro Temp gauge
Xbow Gripper mount
~DOWN&DIRTY~
Old 07-17-2011, 09:24 AM
MUDDIE49's Avatar
Member #858
Well i finally figured it out....took the front cargo box off and did some checks....found the fan relay and a half broken wire.....repaired it...we're back in business...Replaced the relay anyways..and i'm replacing the temp sensor also....it's been threw a few Hott cycles the past few days, Muddie49
2009 Polaris 500 HO
Polaris hand guards
My FenderGuards
EPI Clutch System
SunPro Temp gauge
Xbow Gripper mount
~DOWN&DIRTY~
Old 07-28-2011, 01:43 PM
MUDDIE49's Avatar
Member #858
Having a hard time finding Temp Sensor
Well..the system is running fine, but i wanted to change the temp sensor...i ordered one from Cheapcycle and it was the wrong one, but the guy says that's what it calls for... well its not it's too short and does'nt go in far enough into the cylinder and is completly different...the one that he sent me after 2 weeks is flat at the treads and the one that i need is shaped like a spark plug....with alittle cup on the bottom....he would not let me send it back even when it was still in the bag..., i even check the production date...anyways i checked an 08 model and it has a different number some,i'm going to Polaris on sat and see what goes...Cheapcycle won't be getting anymore business form me.....guy did'nt know his arse from a hole in the ground....told me to ask a Polaris Tech...what is he kidding them tech's won't talk to us.....unless you pay them online...
2009 Polaris 500 HO
Polaris hand guards
My FenderGuards
EPI Clutch System
SunPro Temp gauge
Xbow Gripper mount
~DOWN&DIRTY~
Old 07-28-2011, 02:16 PM
Stealthepooty's Avatar
Member #6542
Moved from Polaris Sportsman to R&M and made Sticky.
_______________________
2010 Polaris 850 XP, Warn XP-30 Winch, KFI Winch Mount, Steel Front & Rear Rack Extenders
My neighbor called the cops because I was playing Radar Love too loud.... they arrested him.
Old 07-28-2011, 02:43 PM
SMP63's Avatar
Member #13545
Sorry to hear of your problem Muddie49 & i will deff. stay away from cheapcycle. Hope you get it fixed tho!
2011 Sportsman 500 H.O. Green
2500# polaris winch
Rev. override kit
Hid 3 light kit
3 light mod. w/relay
Uni air filter on both
Wifes
2011 Sportsman 500 H.O. Red
Hid 3 light kit
Old 08-24-2011, 03:38 PM
Brainless's Avatar
Member #15274
maybe its only your connector being rusted, it could make it intermitent.
Old 12-03-2011, 08:03 AM
Chinno's Avatar
Member #16773
Hey my cooling fan isn't working either however it dose work when i jump straight to the battery and i do get the Hot warning on the speedo what do you think my problem is?I thought it may be the sensor but if it was would i get the warning?Where exactly is this relay and what dose it look like (apart from a rely that is) my conector looks clean.
Thanks.
Old 12-04-2011, 09:58 PM
intimadationrc's Avatar
Member #20204
my fan dont come on and I'm new to this how do i jump the fan to check to see if its the fan or not?
Old 12-08-2011, 05:31 PM
SeanS's Avatar
Member #21174
Chinno and intimadationrc, what year and models do you both have? the cooling system had many changes along the way and could be a number of things depending on the system.
cooling fan sensor location
heatt sensors for atv
how do you jump the temp switch,so the fans will come on?
how to check temp sensor polaris sportsman
how to test heat sencer on polaris atv
how to test temperature switch on polaris 400
polaris 400 fan switch
polaris atv cooling switch
polaris atv fan relay
polaris atv fan switch troubleshooting
polaris fan relay
polaris scrambler temp sensor test
polaris sportsman 800 temp sensor
polaris sportsman 800 temp sensors
polaris sportsman cooling fan switch
polaris sportsman engine temperature sensor
polaris sportsman fan sensor
polaris temp sensor
repairing a thermo fan switch
thermal switch for polaris 500
Need help on a 90 trailboss 250 temp sensor gsbeers ATV Repair and Maintenance 4 07-26-2011 05:45 PM
MAP sensor problem Manny ATV Repair and Maintenance 0 06-21-2011 07:07 PM
cooling system problem atvman2010 ATV Repair and Maintenance 16 01-31-2011 05:40 PM
sportsman 500 ho temp.sensor 4getful2 ATV Repair and Maintenance 3 10-25-2010 05:34 PM
Air Temp Sensor?? Opex Polaris Sportsman 5 06-24-2009 01:05 PM
