03 TrailBoss 330 ignition problem - Polaris ATV Forum
post #1 of 3 (permalink) Old 07-25-2011, 03:08 PM Thread Starter
mmcb's Avatar
Here it goes. I know the coil is good (new). I have reason to believe the CDI is good. (checked). I THINK the little switch by the flywheel (Name? Sort of like a "Hall-Effect" switch.) that signals the CDI when to fire the coil is good. Coil wire from CDI is always hot. Should it always be hot and if so what and how is the coil fired? (Got to either be a hot or a ground switching on and off to fire it and there is no ground. Or to be precise it is grounded all the time through the coil's frame. No seperate ground wire.) Thanks in advance for the help. This is for my 12 year-old son and I'm stumped on it.
P.S. No spark at all.
mmcb is offline
post #2 of 3 (permalink) Old 07-25-2011, 04:35 PM
Bruce! is offline
post #3 of 3 (permalink) Old 07-25-2011, 05:16 PM Thread Starter
mmcb's Avatar
Thanks for the welcome Bruce. Any answers on whether that coil wire should be hot all the time? I am starting to think it might be the CDI after all since the coil is somehow getting 28 volts to it. (All the time which I still think is wrong because with only the hot wire and no negitive wire going to the coil the only way it can fire is if the hot goes dead at some point.)
mmcb is offline
'11 Sportsman 500 Ignition Problem twk87 Polaris Sportsman 12 05-16-2011 04:41 PM
1999 Sportsman 335 Ignition Spark Problem collins5637 Polaris Sportsman 1 02-27-2011 09:05 PM
1998 Sportsman ignition problem? Toyoranger ATV Repair and Maintenance 0 04-24-2010 02:07 PM
Preditor 90 ignition problem? jyarosz ATV Repair and Maintenance 1 12-03-2009 06:44 PM
Ignition problem Martin ATV Repair and Maintenance 13 09-24-2009 08:25 AM
