Old 07-28-2011, 08:15 AM
Polaris Lube---> to Amsoil cross reference guide, does this look right?
Polaris Lube (ProductCode) Amsoil Lube to Use
Premium 2-Cycle Oil (AIT) Interceptor Synthetic 2-Cycle Oil
Premium Gold Synthetic 2-Cycle Oil (AIT) Interceptor Synthetic 2-Cycle Oil
Premium 4 Synthetic 0W-40 Oil, 0W-50 (AFF) 0W-40 PowerSports Synthetic Oil
10W or 20W-40 Oil (MCF) 10W-40 Synthetic Motorcycle Oil
Premium Synthetic Gear Case Lube (SGL-AGL), (TCC) Series 2000 Synthetic Chain Case Oil
PN's 2871280, 2871478 & 2873602
Front/Rear Gear Case Oil GL 80W-90 (SVG) Severe Gear 75W-90 Synthetic Gear Lube
Polaris Premium U-Joint Lube PN 2871515 (GLC) Synthetic Multi-Purpose Grease
Polaris Premium U-Joint Lube PN 2871551 (GWR) Synthetic Water Resistant Grease
Premium All Season Grease (GHD) HD Synthetic Grease
Counter Balance Housing SAE 10W-30 (ATM) 10W-30 100% Synthetic Oil
Premium Hub Fluid PN 2871654 (ATF) Automatic Transmission Fluid
Front Gear Case Oil (SVG) Severe Gear 75W-90 Synthetic Gear Lube
Premium Angle Drive Fluid PN 2871653, 2876160 (SVG) 75W-90 Severe Gear Lube
Old 10-14-2011, 11:51 AM
Polarized's Avatar
Member #18324
Hi Bruce... I'm new to all of this, so please bear with me...
I spoke to a Amsoil Distributor rep today, and although he couldn't tell me if the Amsoil lubes were a direct replacement for the Polaris lube, he did tell me that the "Series 2000 Synthetic Chain Case Lube" is now called "Synthetic Chaincase & Gear Oil" (Code TCC), Amsoil doesn't make the GL5 80-90 (front) gear case oil, but you could use the GL5 75-90 with no problems (Code: SVG), and the Polaris Demand Drive hub fluid, which calls for "Amsoil ATF Type F", would now be called the "Amsoil Synthetic Multi Vehicle ATF".
I guess what I'd like to confirm is if the above Amsoil fluids are the absolute correct fluids that I can use in my 2000 Scrambler 500 to replace the front gear case fluid, transmission/gearcase fluid, and the hub fluid, before I buy them and do this!
Old 10-14-2011, 12:26 PM
North Branch's Avatar
Member #1986
Unless I'm not understanding what you said, I think AMSOIL does make an GL-5 80-90 gear lube. Here's the link...
https://www.amsoil.com/storefront/agl.aspx
I know this, as I have used it in my ATV's.
Old 10-14-2011, 12:47 PM
Polarized's Avatar
Member #18324
Ok, excellent... so I could use Amsoil GL-5 80-90 as a direct replacement when changing the oil in the front gear case - thanks North Branch! I will point this out to the guy. Have you used the Amsoil "Synthetic Chaincase and Gear Oil" for the gearcase/transmission then?
Old 10-14-2011, 01:04 PM
Member #1986
Yikes, we are ruining Bruce's thread. Sorry Bruce.
Anyhow...
Yes, I used the AMSOIL Chaincase oil in my 500 HO when I had it. Worked just fine, but I didn't have the quad long, so I don't know how it is long term... but I'm betting it's excellent.
For a non-Hilliard front differential requiring GL5... either 75-90 or 80-90, I actually prefer this AMSOIL product.
https://www.amsoil.com/storefront/agm.aspx
Old 10-14-2011, 03:03 PM
Polarized's Avatar
Member #18324
Thanks again North Branch, and yes I agree, huge apologies to Bruce for ruining his thread... but the post was a perfect segway for my "fluid issues"... LOL. And now that I'm here, I can't help but ask... "Amsoil Synthetic Multi Vehicle ATF" - good for the hubs? Yes, no? Thanks again folks!
Old 12-02-2011, 03:18 PM
How about this chart!
http://www.purepolarisoil.com/pdf/Ma...e_ATV_2010.pdf
Old 12-02-2011, 03:23 PM
KICKER431's Avatar
Member #18006
Love the Chart. Wish I had access to that a few months back when I was making my own chart for my 2 machines. Cross checking with this chart I did pretty well. My one on the wall in the shop matches up nicely except I change fluids more often than it says.
2004.5 Sportsman 700 EFI
2007 Sportsman 700 EFI
Old 02-05-2012, 03:51 PM
Camo850xp's Avatar
Member #12040
Question Oil Cross Ref
How about amsoil for 2011 850xp?
Old 02-05-2012, 05:51 PM
Polaris Bear's Avatar
Member #1031
Amsoil, Powersports 0W-40 will work great in your machine.
Mine 2009 Sportsman 850 XP Camo, Bighorn 2.0 tires, rear cago box with back rest, steel rear rack extender, Oury Grips, Polaris grip warmers, thumb warmer, Polaris fender bag, Promark 3,000 XTR winch, polaris Handguards, extreme front brush guard with PIAA lights, custom front rack Rotopax fuel pack carrier.
Hers 2009 Sportsman 400HO Camo, Warn 1,500, winch, Polaris Handguards.
Grandson 2001 E-Ton Rascal 50
Ours 2009 Fuzion FZ302 35ft 5th wheel Touring Edition toy hauler.:usa
agl synthetic gearcase lubricant
cross reference polaris oil
polaris agl synthetic gearcase lube
polaris angle drive fluid substitute
polaris cross reference for lubricants
polaris demand drive fluid substitute
polaris demand drive hub fluid
polaris lube cross reference
polaris lubricants
polaris oil cross reference
polaris premium agl synthetic gearcase lube
polaris premium drive hub fluid
polaris premium hub lube
polaris premium synthetic gearcase lubricant
polaris synthetic gearcase oil
polaris to amsoil cross reference
premium agl synthetic gearcase lubricant
premium polaris demand drive hub fluid cross ref
John Deere cross-reference Diff part numbers?? primetime1267 Polaris Sportsman 1 07-26-2011 04:35 PM
Polaris Lube -->> Amsoil Cross Reference mngatorhunt Polaris XP 6 03-19-2011 05:56 PM
Polaris lube chart Razorback ATV Repair and Maintenance 1 02-12-2011 05:14 AM
01 sportsman battery cross reference turbocav22 ATV Repair and Maintenance 1 05-10-2010 07:53 AM
