conecting rod to crank clearance 400 scrambler - Polaris ATV Forum
post #1 of 4 (permalink) Old 07-28-2011, 05:47 PM Thread Starter
droptop's Avatar
Hello I am rebuilding a 95 scrambler 400. I just replaced the conecting rod (large end) bearing and pressed the crank together. My question is how much play should there be between the conecting rod and crank/thrust washers. My repair manuel does not list this spec.
droptop is offline
post #2 of 4 (permalink) Old 07-28-2011, 07:59 PM
Bruce! is offline
post #3 of 4 (permalink) Old 07-29-2011, 01:30 AM
mstermechanic907's Avatar
Send a message via MSN to mstermechanic907
you have to press the crankshaft together flush with the crankshaft lower connecting rod pin.are you using the polaris spx brand crankshaft rebuilding kit? do you have the crankshaft holding stand for truing the crankshaft? i also have the two micrometers with magnetic stands.when truing the crankshaft polaris allows .002 of movement on the micrometer scale, i true to .000 racing specs.you should have about .02 to .03 clearance between the crank pin thrush washer and crank wheel.thats assuming you installed new thrush washers.
mstermechanic907 is offline
post #4 of 4 (permalink) Old 07-29-2011, 04:59 AM Thread Starter
droptop's Avatar
I just have a press vblocks and dial indicater. But so far I have it spining true to about. 003. I used a new bearing and washers. But couldn't find a kit for a scrambler through hotrods or wiesco. I have a bit more play then that so ill try pressing it a little closer.
droptop is offline
WTB: Pipe for 98 Scrambler 400 and socket for slotted nut on crank carl425 ATV Parts for Sale 1 04-30-2011 08:04 PM
polaris scrambler 400 crank polcat1p Polaris Scrambler 5 08-25-2010 05:54 PM
1999 scrambler 400 crank polcat1p ATV Repair and Maintenance 1 08-22-2010 10:16 AM
where can i find scrambler 400 stroker crank? gettherefast Polaris Scrambler 5 04-15-2010 08:45 PM
1994 400L 2-stroke crank to rod clearance JOHNAMYX ATV Repair and Maintenance 2 01-24-2010 01:09 AM
