ATP Oil leak question....help! - Polaris ATV Forum
post #1 of 4 (permalink) Old 07-28-2011, 08:49 PM Thread Starter
cbringed's Avatar
2004 ATP, 330-
I have oil leaking from the brass pressure fitting leading (or returning) from the oil cooler on the motor side. I removed the fitting from the block and it looks fine. I put teflon tape on the fitting and reinstalled with no luck? What am I missing?!?
cbringed is offline
post #2 of 4 (permalink) Old 07-28-2011, 11:25 PM
mstermechanic907's Avatar
Send a message via MSN to mstermechanic907
you might have a slight blockage/restriction of oil flow in the oil lines or oil cooler.i would unhook the oil lines behind the oil filter and with compressed air blow out the lines.put a container under one end of the oil lines to catch any oil still in the oil cooler.we've had a slightly blocked oil cooler on the same machine,leaking from the pressure oil line.we ended up changing the cooler.we compaired the air pressure coming out of the new cooler compaired to the old cooler,you can hear the difference.that fixed the leaking line/fitting.
mstermechanic907 is offline
post #3 of 4 (permalink) Old 07-29-2011, 05:16 AM
Bruce! is offline
post #4 of 4 (permalink) Old 07-29-2011, 02:42 PM Thread Starter
cbringed's Avatar
Update
Update....after double and triple checking the brass fitting and cooler, I noticed that where the line goes into the oil case is cracked. Called a buddy of mine at the dealership who told me that this happens on rare occasions. They actually came out with a new replacement tank to stop this problem.....sounds expensive!
cbringed is offline
Tags
330 , atp , oil leak
2000 Polaris Sportsman 500 4X4 - seal leak question degilmer Polaris Sportsman 1 04-06-2011 08:59 AM
Oil leak Muskyhunter ATV Repair and Maintenance 3 04-03-2011 03:21 AM
Oil Leak yanks2362 ATV Repair and Maintenance 5 02-09-2011 01:48 PM
gas leak shawnboy87 ATV Repair and Maintenance 8 09-16-2010 02:15 PM
Help! Oil leak 02 700 dtsesthx Polaris Sportsman 2 04-22-2010 12:10 AM
