2002 Sportsman 700 transmission problem? - Polaris ATV Forum
post #1 of 4 (permalink) Old 07-30-2011, 09:13 PM Thread Starter
smsparky36's Avatar
Question 2002 Sportsman 700 transmission problem?
I am new to the site but I have read many forums and they have been very helpful. I have a problem with my 2002 Sportsman 700, it has been running great but recently it started making a loud "whining" or "howling" sound in high gear. It sounds like it is coming from the transmission, since it doesn't do it in low gear. It also only seems to do it when you are accelerating, but if you coast downhill it quits? Does anyone have any ideas or experienced a similar issue? Any input would be appreciated.
smsparky36 is offline
post #2 of 4 (permalink) Old 07-31-2011, 12:10 AM
mstermechanic907's Avatar
Send a message via MSN to mstermechanic907
that is the first model 700 sportsman,how many miles?you might have a bearing just starting to go out.whats the transmission oil level at? was it run low? are their any metal shavings in the trans oil?whining is most likely from a worn out brearing or a bearing that was run dry for awhile.i will try to help you out but need more info.
mstermechanic907 is offline
post #3 of 4 (permalink) Old 07-31-2011, 06:12 AM
Bruce! is offline
post #4 of 4 (permalink) Old 07-31-2011, 07:33 AM Thread Starter
smsparky36's Avatar
I bought it used and it has 3500 miles. I have not check oil level or drain it yet I just got back from the hills last night. I will take a look at the oil today.
Thanks for the help.
2002 Sportsman 500 6x6 transmission LT512 Polaris Sportsman 2 07-11-2011 08:07 PM
2002 sportsman 700 overheating problem fattkt77 ATV Repair and Maintenance 28 02-20-2011 11:39 AM
2002 magnum rmk transmission problems mech63s ATV Repair and Maintenance 3 01-01-2011 03:13 PM
2002 Sportsman speedo problem TimberGhost ATV Repair and Maintenance 4 12-31-2010 02:39 PM
2002 sportsman 500 HO 4x4 problem bigsky Polaris Sportsman 0 04-03-2010 09:44 AM
