90 predator oil injector adjustment - Polaris ATV Forum
Old 08-10-2011, 07:18 PM
Denisb's Avatar
Member #17394
Anyone have the adjustment procedure for the oil injector and carburator adjustment from the service manual? I just bought a used 90 for my son and want to make sure it doesn't run low oil mixture.
Thanks,
Denis
Old 08-28-2011, 07:04 PM
Thor2911's Avatar
Member #5060
Post
I have a manual for my 1995 400 2-cycle that may be of some help. Let me know and I would copy it and share it with you.
I know you can not have any slack on the cable going to the injection pump from the throttle or it will not get enough oil. I believe it states that the throttle and oil injection must open/move at the same time.
06 predator 90 carb setting
adjusting oil injection in polaris 90
how to adjust oil injection on a polaris
oil injection for predator 90
polaris 90 oil injection
polaris 90 oil injection adjustment
polaris 90 oil pump adjustment
polaris oil injection adjustment
polaris predator 90 oil injection
polaris predator 90 oil injection adjustment
polaris predator 90 oil mix
predator 90 oil pump problems
Predator 90 injector ol suggestion Denisb ATV Repair and Maintenance 2 08-06-2011 10:01 PM
Predator 500 clutch actuator arm adjustment Taiperas ATV Repair and Maintenance 2 05-06-2011 06:45 PM
2005 Predator clutch adjustment help :( donjuandr Polaris Predator 1 07-22-2010 07:23 AM
2005 Predator clutch adjustment help :( donjuandr ATV Repair and Maintenance 1 07-21-2010 04:21 PM
