sportsman 500 EFI wont start - Polaris ATV Forum
post #1 of 6 (permalink) Old 08-13-2011, 08:14 PM Thread Starter
schalid's Avatar
I have a 2006 sportsman 500 efi and it has sat in the garage for a year. It cranks over but I dont think its getting gas. Not sure about spark as I cannot get at the dang spark plug to check it. I used to turn on the key and it made a fairly loud buzz like sound, now it is much more faint. Any suggestions?
Thanks.
schalid is offline
post #2 of 6 (permalink) Old 08-14-2011, 06:46 AM
catmando31's Avatar
remove the seat and soak a rag in fresh gas.hold it over the air intake pipe with your hand.if your getting spark the bike will start and run from the gas fumes.if it does run like this the throttle body is gummed up with varnish from the old gas.put some sea foam in the tank and and run it with the rag until it will idle on its own.may or may not work,you might have to have the throttle body cleaned.but if it will stay running the seafoam will clean it up after a decent length ride.
2008 honda 700xx grey and black. 2008 mossy oak sportsman 800 H.O. 27" MUD TRAX TIRES on 14" sti wheels,3000 lb gorilla(promark) winch,front and rear PURE POLARIS brush guards.
catmando31 is offline
post #3 of 6 (permalink) Old 08-14-2011, 07:42 PM
Bruce! is offline
post #4 of 6 (permalink) Old 08-17-2011, 01:14 PM Thread Starter
schalid's Avatar
Put hand over air breather hole and it started once for a sec. That was it. It has spark but no gas. Took off line at fuel filter and no gas. When I turn the key on I do not hear a buzz like sound like I used to. Fuel pump??
schalid is offline
post #5 of 6 (permalink) Old 08-18-2011, 10:28 AM
sfrasher's Avatar
The buzz is probably the fuel pump. It would probably sound different if there was no fluid versus if there was fluid.
Spence
2001 Trail Boss 325, AA model, since April 2011
"I've been sane, and I've been crazy. Crazy is more fun!"
sfrasher is offline
post #6 of 6 (permalink) Old 08-18-2011, 01:49 PM
7.62Addict's Avatar
Check to see if the fuel pump is getting power/round. If it is, and it wont run its a bad pump. You may need to try cranking while you check so the pump is being commanded on.
7.62Addict is offline
Sportsman 500 wont start Rebelcbowhunter ATV Repair and Maintenance 2 07-19-2011 10:25 PM
07 Sportsman 500 efi wont start usaf042886 ATV Repair and Maintenance 2 07-10-2011 11:49 PM
Sportsman 500 wont start. incadave Polaris Sportsman 2 11-02-2010 03:43 PM
450 sportsman wont start casey ATV Repair and Maintenance 3 09-28-2010 08:58 AM
2004 sportsman 600 wont start gnv11 ATV Repair and Maintenance 1 06-17-2010 06:01 AM
