2001 Sportsman 500 HO won't shift to high - Polaris ATV Forum
post #1 of 5 (permalink) Old 08-24-2011, 04:17 PM Thread Starter
RightDownUpLeft's Avatar
So as the title says, my quad will shift to reverse and low...but grinds and won't shift into high.
The sun of pup will randomly shift to high after being in reverse...but not steadliy
If I turn the ATV OFF and shift it to high, turn it on, it runs fine with no issues...dosen't pop out or anything
WTF? Is the issue
Thanks Guys and Gals
RightDownUpLeft is offline
post #2 of 5 (permalink) Old 08-24-2011, 05:55 PM
Bruce! is offline
post #3 of 5 (permalink) Old 08-25-2011, 01:27 AM Thread Starter
thank you!!!
Anyone have a clue??
another board is thinking shift linkage rod needs to be lengthened or shortened...
post #4 of 5 (permalink) Old 08-25-2011, 04:18 AM
tt425's Avatar
I think the gear shift linkage needs to be adjusted. Soak the threads with PB BLaster or other penatrating oil before adjusting. Note the end at the shifter is left hand threads. Loosen the jam nuts on both ends of the rods then adjust. You might have to adjust both rods to put them in sequence together.
tt425 is offline
post #5 of 5 (permalink) Old 08-25-2011, 09:37 AM
TinkerMan's Avatar
If the idle is to high it will do that..dose it try to move when its running at idle could be the drive clutch? are you pushing down on the foot brake to go to high or park..ur posta.
Todd PolarisATVrepair.com | Local ATV Full Service, Engine Rebuild Services, Engine Rebuild Kits, Clutch Puller, Bearing Kits and more!
TinkerMan is offline
'98 Sportsman 500 Won't Shift Into Low crusher44x Polaris Sportsman 3 06-20-2011 03:59 AM
06 sportsman 800 won"t shift rookie racer ATV Repair and Maintenance 5 06-10-2011 04:34 PM
Xpress won't shift into high Xpressman ATV Repair and Maintenance 4 02-14-2011 04:43 AM
2001 Trailblazer high idel Nuworld Polaris Trail Blazer 6 09-11-2010 07:27 AM
2001 400 explorer wont go into high gear eb156 ATV New Members 5 08-31-2010 05:39 PM
