06 500 EFI X2 won't start, backfires - Polaris ATV Forum
post #1 of 12 (permalink) Old 09-03-2011, 10:37 PM Thread Starter
RedEarl's Avatar
I shut off the quad and now it won't start.
06 500 HO EFI X2
Turns over but won't run, smell fuel and I would get a backfire or two
Checked fuel- ok
Spark-ok
Injector- ok
Moved on to checking timing and valve lash clearance Ok, thought maybe the chain slipped, but timing is ok per service manual.
I am stumped at this point, could it be a sensor (cam) or something telling the computer to fire spark/fuel off time?
Thanks in advance for your brainpower. Hope I can get to the bottom of this.
-Mike
RedEarl is offline
post #2 of 12 (permalink) Old 09-04-2011, 06:29 AM
Bruce! is offline
post #3 of 12 (permalink) Old 09-04-2011, 07:29 AM Thread Starter
RedEarl's Avatar
Thanks Bruce! Great site, lots of good information.
I am going to keep digging in the service manual today to see if I can diagnose the run problem. No clue as of yet.
Thanks,
-Mike
RedEarl is offline
post #4 of 12 (permalink) Old 09-04-2011, 07:14 PM Thread Starter
RedEarl's Avatar
Bump.... Checked all of the sensors with ohm tests and voltage checks I am realy confused. It won't run just backfires. It's like timing is off but I have made sure it is dead on.
Need help.....
-Mike
RedEarl is offline
post #5 of 12 (permalink) Old 09-05-2011, 08:07 PM
usadaytrader's Avatar
bad gas? That was my problem. I bought a used Sportsman. Ran great the first day (took long to crank tho). Couldnt get it started the next day. It would crank and backfire. Mechanic said it was bad gas. Now I put seafoam in all my gas containers. Same crap happened to my generator.
usadaytrader is offline
post #6 of 12 (permalink) Old 02-11-2012, 07:28 PM Thread Starter
RedEarl's Avatar
Still won't run
I have gone through the engine, checked top end out with caliper and everything is in spec. I am fearing the worst that it is electrical of the ecu....
I have codes
42
22
45
46
I am not sure what part to swallow next$$$ to figure out what is going on...
The quad has the same symptoms as my first post.. Back fires. Even out the intake. Will not fire correctly.
I hope someone can give me some advice on this, as I am not sure what to dig into next...
Thanks,
Mike
RedEarl is offline
post #7 of 12 (permalink) Old 02-11-2012, 08:33 PM
ebaysnyper's Avatar
Send a message via Yahoo to ebaysnyper
Sounds like the ecm or whatever its called. Find someone close to you that has a 500 from 04.5 to 08ish and see if you can swap test.
Sent from my DROID3 using Tapatalk
2007 sportsman 500 x2 efi
26" sadona ripsaws on 12" itp ss312's
3 headlight mod relay type
2500 Ib polaris winch
custom made "winch saver"
custom work light mod with lighted switch and 18 Watt lamps
custom stealth black shock covers
Front trunk locks Polaris Part #2874548 $7.50 each @ dealer
front rack rails converted to "U channel" strut for easy attachments
pure polaris HD front springs
ebaysnyper is offline
post #8 of 12 (permalink) Old 02-11-2012, 08:40 PM
ebaysnyper's Avatar
This guy has a link for a pdf of the codes
http://www.atvnation.com/forum/index...5&#entry314235
post #9 of 12 (permalink) Old 03-22-2014, 02:36 PM
pedals's Avatar
did you figure it out?
I'm having the exact same problem with my 08 sportsman 500, did you eve figure out what was wrong with your bike?
pedals is offline
post #10 of 12 (permalink) Old 03-22-2014, 05:25 PM
kroeger's Avatar
Sounds like a timing issue to me. Good call on the test ECM swap if you can get your hands on one...?
Sportsman 500 HO 2008
49" Polaris plow
polaris hand warmers
polaris thumb warmer
lock and ride rear box
lock and ride tall green windshield
lock and ride gun boot
polaris front brush guard
polaris rear bumper
custom gun/bow mount on front rack
27" zillas
HD3 wheels
Qsc clutch
kroeger is offline
Tags
500 efi sportsman 2006 , won't run
polaris backfires ericbrown ATV Repair and Maintenance 3 08-03-2011 06:35 AM
99 Sportsman 500 sputters and backfires JodieJens ATV New Members 3 06-11-2011 10:24 AM
help backfires smit72 Polaris Sportsman 4 12-28-2010 06:27 PM
95 Magnum 425 backfires Spitfire79 ATV Repair and Maintenance 5 04-20-2010 04:04 AM
Backfires all the time cpowers592 ATV New Members 5 04-10-2010 07:58 PM
