09-05-2011, 10:57 PM
Member #18308
98 express 300 brake bleeding
Can someone tell me the best way to bleed brakes on 98 express 300. The brake lines are empty. I replaced the part that was needed. Do you bleed them one line at a time or separate?
09-06-2011, 05:08 AM
Member #1958
You start at the caliper farthest from the master cylinder and work your way to the closest. Then go back over them again till you get all air out. Make sure to keep the MC topped up during the whole process or you'll pump air back in the system and have to start all over again.
09-06-2011, 05:57 AM
Member #18308
Thank you so much!
10-08-2011, 03:23 PM
Member #19398
help
Hello,
I have a 99 express could you tell me where the 2 wires on the cdi harness plug in to. I think 1 goes to the coil but I cant find on the board the black one goes.the board is right behind the oil tank.thanks
10-08-2011, 03:37 PM
Originally Posted by superdude
Hello,
WELCOME SD,
I suggest you start a new thread for this topic. It will get lost here and you will likely get more views and better answers.
2007 Polaris Sportsman 700 EFI W/ 26" Maxxis Big Horns, Crusher Black alloy rims, EPI clutch kit, EPI HD springs F&R, Moose front/Ricochet rear CV guards, UNI air filter, Moose camo tank bag, F&R rack extensions, Lock-N-Ride lo & hi windshields, Acerbis hand guards, CUSTOM mirrors and a 3000# Gorilla winch, W/Am-steel blue synthetic line, running thru a winch saver and an aluminum fairleed. Thor's foot pegs and CUSTOM rear rack support frame and WES seat box. CUSTOM front and rear mud flaps.
NEW: CUSTOM SIDE MOUNTED 1.5 Gal Kolpin gas cans & 800 dual Exhaust.
10-08-2011, 03:55 PM
Member #18308
There's a free download of Polaris service manual for 96-98 in the stickys at the top of the Repair and Maintenance section that may have some info to help you till your manual arrives.
Good luck and let us know if you run into any problems you can't figure out. If that doesn't help let me know and I will pull the body panel off mine and look for you.
10-08-2011, 03:57 PM
Member #18308
bleed front brakes on polaris xpress, bleeding brakes on polaris xpress, how to bleed brakes on a polaris 300, how to bleed brakes on a polaris 300 express, how to bleed brakes on a polaris express 300, how to bleed brakes on polaris 300 xplorer, how to bleed brakes polaris xpress, how to bleed front brakes on a polaris xpress 300, how to bleed polaris xpress brakes, how to bleed the back brakes on a polaris express 300, polaris 300 atv auxillary brake problem, polaris 300 brakes bleeding, polaris bleeding issues, polaris express 300 brake system, polaris xpress 300 brake bleeding
