HELP! 2006 Sportsman 700 EFI Dies for No Reason - Polaris ATV Forum
Old 09-09-2011, 11:31 AM
AKStew's Avatar
Member #5212
I posted a thread several days ago that I had my 2006 Sportsman 700 EFI fixed--NOT!
Now I need to pick your brains some more.
My machine will run great for hours--and sometimes days--and then just die for no reason. Any RPM, any speed, it just dies--no rhyme or reason as to dry trail, wet trail, mud bog, hot weather, cold weather. If I try to restart it immediately it will seem normal for a second or two then die again. If I continue to try to restart it every minute or two, it runs longer with each subsequent restart, until finally it will run fine (minutes or days--who knows). It usually takes about 30 minutes to an hour for it to restart and run normally again. It throws no trouble codes when it dies and the speedo is not flashing HOT either. The fan seems to be cycling on and off when it needs to.
It could be heat related because it only does it at operating temperature and it restarts after a short period of time, which means it has also cooled down somewhat. It could also be an electrical problem.
To date, this is what Iíve done:
I've changed the fuel pump and filter sock inside the gas tank, and the voltage to the pump is good. I dismantled the entire fuel system, cleaned out the gas tank, gas lines and fuel rail, changed the filter and burned a tank of gas treated with Sea Foam. The fuel tank vent is also good. I've also covered the bottom of the gas tank with foil insulation.
The air filter is clean and the rubber intake boot between the air filter box and the throttle body is not cracked or rubbed through. The plastic throttle body adapter tube to the head is also in good condition. The clamps are tight in all the right places. The oil is clean and full as are all the other lubricants.
I changed the t-bap sensor, installed the beefier harness (the original was broken on the inside), changed the TPS (which was bad and I thought would be the final solution), and adjusted the TPS to within a thousandth of a volt of factory specs (zero offset and idle voltage). The TPS output reads good at the ECU plug as well. Spark plugs are in good condition and the coil and wires check out good.
Iíve removed and cleaned the contacts on the power and fan relays and their sockets (they were only slightly dirty but seemed to be making good contact). The fan works as advertised. The resistance at the coolant temperature sensor and the crankshaft position sensor are reading within specs at the ECU plug.
Iíve checked continuity for every circuit related to the EFI and found nothing out of order, though that doesn't mean there's not a short somewhere after she gets warmed up. The battery is strong and reads 12.8 volts. The machine reads 13.8-14.1 volts at idle.
Here are some possibilities that I can think of that I can do yet:
Change the TPS harness on the machine side (I plan to do this tonight), check the operation of the power and fan relays, and check the operation of the ECU. Change the self-resetting circuit breakers. Check the voltage regulator.
Anything I left out?
Iím running of the simple things except for the TPS harness and Iím afraid Iím narrowing it down to the ECU, which I donít want to replace at $400+.
Is there a way to check the operation of the relays and ECU myself? If I take it to the dealer it may or may not duplicate the problem and there goes a $100 in diagnostic labor.
Any and all input is much appreciated.
Thanks,
Stew
2011 Sportsman 500 HO Touring: Polaris 3500 lb. Winch, Kimpex Adventure XL Trunk, 7" Passenger Foot Risers, UNI Foam Filter
2006 Sportsman 500 X2 EFI: Superwinch Terra 25 w/Synthetic Rope, Kolpin 4 gal Gas Pack, 3" Passenger Foot Risers, 3-Headlight Mod, K&N Filter
SOLD 2010 Sportsman 300: Polaris 2500 lb. Winch, Kolpin Rear Seat (for the dog), UNI Foam Filter
SOLD 2006 Sportsman 700 Twin EFI: 27" Mud-Lite XTR, Superwinch Terra 35 w/Synthetic Rope, Polaris HD Front Springs, OEM Front Bumper Guard, WES Rear Seat, Kimpex Fender Guards w/Footpegs, 3-Headlight Mod, K&N Filter, Symtec Heated Grips
Old 09-09-2011, 09:03 PM
Hunt79's Avatar
Member #18132
I worked on a 700 EFI ranger today that's been having exact same symptoms. I disconnected all the harnesses and cleaned them one by one and checked it. Finally after the crank sensor was disconnected cleaned and reconnected it started and ran fine. I drove it till it engine was warm and couldn't make it stall out anymore. I hope that fixed the problem if not may be looking at a ECU
Old 09-10-2011, 10:27 AM
AKStew's Avatar
Member #5212
Nice job. One day I will come across the problem and my machine will work as well.
Stew
Old 09-10-2011, 05:42 PM
WalterS's Avatar
Member #12678
Have you checked for strong spark when it takes a notion to quit?
2007 Sportsman 800
1500 miles, mostly at Hatfield-McCoy trails, WVa.
Old 09-11-2011, 05:34 PM
AKStew's Avatar
Member #5212
No. I'm usually several miles from camp when it happens. What would you carry in your tool kit to check the spark in the field?
Thanks,
Stew
Old 09-11-2011, 07:14 PM
WalterS's Avatar
Member #12678
Probably the easiest would be an inductive type spark/high voltage detector. You hold the sensor next to the high voltage plug wire while cranking and it detects the presence of high voltage/spark.
Alternatively a used/ but good spare sparkplug that has a length of wire fastened to its body with a hose clamp. On the other end of the wire I put a medium sized alligator clamp so that it can be clamped to a good ground. I remove the plugwire from the plug in the head and put it on the used plug. Crank it over and look for spark.
This might be tricky to do since the atv will be hot, presumably.
2007 Sportsman 800
Old 09-13-2011, 04:41 PM
jroptop's Avatar
Member #8974
Is there a change in pitch of the fuel pump when its priming on initial start up after it shuts down and you try to restart it?Im just wondering if its going into "vapor lock"?
2005 Sportsman 800-handguards,viper 54" plow,headlight mod,hids low and hi,hand warmers,reverse light kit,SS212 rims,bear claw tires
2002 Silverado 2500 HD ext cab 8.1
2002 Corvette convertible triple black
Old 09-13-2011, 09:25 PM
AKStew's Avatar
Member #5212
I have noticed it doing that but only once or twice; and fuel comes out of the test port if you push the core in, though I don't know at what pressure. Could you elaborate?
Old 09-13-2011, 10:28 PM
IKEA52's Avatar
Member #14603
Good Day All,
My 2011 Polaris 550 EFI EPS did that one day out in the field, twice. The weather and riding conditions were great, beautiful 30C day and the trails where hard packed and dry. The first time it did it i was on a straight stretch and went to accelerate and there was no response, so i stopped put it in neutral and it started right back up. We stopped later on down the trail for lunch and i opened the engine compartment to allow it to cool as it seemed hot. After about an hour we started to make our way back to camp, on the way back same thing happened again.
Once back to camp i opened the engine compartment again to allow it to cool down while we ate dinner, about two hours later we went for another ride for about an hour with no problems. Mind you both the machine and the outside temperature cooled.
When i got back home i phoned my Polaris dealership to ask what could be causing this as i couldnt find anything wrong with it. They advised me to bring it in and have it checked as it was only four months old. Well after 2 full days of working on it and ripping it all down and building it back up they could not find anything wrong. I havent had a chance to take it out lately to see if it is going to do it again but the REALLY short distances i have ran it so far it has been good.
If you do find a cause and dont mind please drop me a line so i can check it out on my machine.
Old 09-18-2011, 05:20 PM
Pelkey's Avatar
Member #18737
I have a 2005 800 sportsman EFI. Same problem. Were you able to solve thi sone. Seems to b pretty common! Man thanks I wuod also think polaris shold be on top of this one because it is soe common. But they do not seem to be.
2007 polaris ranger runs and dies
my 2007 polaris 800 sporstman just shuts off and then restarts right away
polaris 700 dies and wont stay running after riding it a while
polaris ranger 500 crankshaft position sensor
polaris sportsman 500 efi vaporlock
polaris sportsman 700 dies after riding it for a while
polaris sportsman 800 dies while riding
polaris sportsman 800 randomly dies
polaris sportsman dies
sportsman 700 stalls hot
when outside temperature is hot my polaris ranger turns off
youtube polaris 700 sportsman quits after getting warm
2006 Sportsman 700 EFI "dies above idle" NEED HELP ASAP FOR WEEKEND RIDE xlwater Polaris Sportsman 6 12-29-2012 10:59 PM
2006 sportsman 500 h.o dies unless thumb is on gas LT1C3 ATV Repair and Maintenance 9 01-10-2011 08:21 PM
please help! cant find the reason preddy500 Polaris Predator 3 05-25-2010 11:42 PM
Reason for going through batterys? nastypredatorBV Polaris Predator 6 03-07-2010 12:04 PM
reason to believe jgalbraith ATV New Members 2 08-21-2009 07:30 AM
